DT Swiss End Caps /...
DT Swiss End Caps / Conversion Kits
2 Users
Hi all,
Can anyone advise if there's an aftermarket alternative to DT end caps, looks like £35 per wheel to change which is a bit hard to stomache...
Cheers,
Al
Posted : 13/10/2022 10:01 am
There is not no, other than some boost adapters. If you know *exactly* what you need then it is often cheaper second hand but you do need to be confident you have identified the correct part as there are a lot that are similar. Note there are also the parts DT say are 'not compatible' that actually are (e.g. road 12mm end caps for 15mm 350 mtb hubs).
Posted : 13/10/2022 10:23 am
Thanks, yes I've seen various charts showing the options, didn't appreciate there were off-chart options though!! This would be for 350 road hubs converting from QR to 12x100 & 12x142.
Posted : 13/10/2022 10:53 am
