Dehumidifiers...are...
Dehumidifiers...are they the answer to my problem?
28 Users
38 Reactions
2 years after some house renovations the front room and the sofa smell a little damp. The room is at the end of the house and hence probably doesn't get a lot of air circulation (it's also the gable end).
It's an old stone built house and other rooms have various degrees of moisture in the lower walls however they've been like that for about 20 years and cause us no issues really (perhaps wooden flooring doesn't let the moisture escape so it does so through the walls)
Anyway, I've just become aware of dehumidifiers...could a unit in my front room keep moisture levels down, air circulating and thus cure the damp smell (or at least it not getting worse)
If so...which and what sort do I need???
Posted : 26/09/2024 7:33 am
 mert
Quite possibly. It's fixed the (slight) damp issue in my basement.
More air circulation would usually be the first port of call though.
Posted : 26/09/2024 7:44 am
They help but one of them running intermittently won't do much for the damp levels within a house overall, even a small one. We've found opening the windows early in the morning for 15-30 mins before the heating comes on far more effective in reducing any effects of damp. Colder drier air heats up more easily and tbh I haven't noticed a difference in warmth since the habit of letting air circulate early am. I like the fresh cool air too.
Posted : 26/09/2024 7:48 am
hammerandcycle, thelawman, andybrad and 3 people reacted
Yeah, it'll certainly help but won't solve the problem. We use one in the winter months when drying clothes inside.
Posted : 26/09/2024 7:49 am
Hiya,
We too have a stone house. Our damp problem was caused by poor pointing and wrong pointing material. Once I removed the cement pointing and replaced with lime mortar, all was good. I also dug down on one side and fixed drainage and let the walls breathe better it was all fixed.
Oh yes are the walls clad?
BR
JeZ
Posted : 26/09/2024 7:50 am
We live in a three hundred year old, solid brick wall cottage and have a dehumidifier running on low most of the year and it has cured all of the damp and black mould we used to get especially on our gable walls.
Dry air is easier to heat so the running costs are offset by reduced heating costs.
Posted : 26/09/2024 7:56 am
findusomally, mezimov, chakaping and 3 people reacted
Positive air fan would sort it or maybe an extract fan with humidistat. If not possible Meaco dehumidifiers are good especially if you can run a drain hose from the unit . Otherwise you have to empty the reservoir often.
Posted : 26/09/2024 8:09 am
Maybe light the fire? That’ll draw the air through it like when it was built
Posted : 26/09/2024 8:50 am
They do work very well. We use ours in the kitchen to dry clothing, with the added benefit the moisture from cooking is removed - we no longer get mould forming on the bay window in the kitchen.
There are three types. Cheap Peltier ones that aren't great, compressor ones that work well, and desiccant, The latter is supposed to be best, but reviews say they guzzle electricity so check the power consumption.
Posted : 26/09/2024 9:02 am
As reccomended off here we bought a maeco 8litre zambesi desicant dehumidifier.
Works a treat. Got timer controls so we don't run it 24/7
Posted : 26/09/2024 9:23 am
Compressor dehumidifier with a 12-16l daily capability will work well.
Posted : 26/09/2024 9:37 am
 Jamz
+1
What renovations did you have done? In old houses with no damp proof course, the walls need to be able to breathe so that they don't get damp. That means lime mortar on the outside and lime plaster on the inside - no cement, because it doesn't breathe. It also means traditional paints that are breathable. I would also be checking the drainage outside the property, corresponding to where you have the damp inside.
Posted : 26/09/2024 10:07 am
There are three types. Cheap Peltier ones that aren’t great, compressor ones that work well, and desiccant, The latter is supposed to be best, but reviews say they guzzle electricity so check the power consumption.
I've just posted about this as I've just been looking into buying one..... it's not exactly that clear cut.
Posted : 26/09/2024 10:52 am
As above what were the renovations? Was adequate ventilation put in?
Positive Pressure Systems would help, and actually I think are a good thing in any old has that has a dampness about it.
TBH I am not a fan of the dehumidifier, yes they take the moisture out, but they dont help air circulation
Posted : 26/09/2024 11:11 am
If you are anywhere near North Yorkshire you can have the one I have sitting around doing nothing. (was used in previous house)
Posted : 26/09/2024 11:15 am
Bonus, just managed to fix the old dehumidifier that sits in the detached garage protecting the tools, bikes and camping gear. It's a good 20 years old but the buttons had gotten unreliable and had a mind of their own eventually resulting in them doing nothing.
Was about to bin it then thought I'd try and access the circuit board and 'buttons'. Got it to bits and the board was full of fluff. Brushed off and blasted the whole board and buttons with electrical contact cleaner. Back together and it's working again.
It's tatty, yellowed, but stops damp well in the garage. I've had times when all the surfaces are sweating due to a sudden temperature change outside.
Needed something fixing as our tent is polycotton and prolonged damp will do it no favours.
Posted : 29/09/2024 1:32 pm
BearBack, kelvin, hightensionline and 2 people reacted
We went PPV.
Not looked back. Cost 350 quid to fit but has reduced our condensation issues to nil.
We used to get condensation on the windows....and we coped. Quick karcher vac and it was gone.
Replaced those windows with new double glazing. -the dew point moved to the dormer cheeks due to poor insulation- and this meant mould.
The PPV has removed that. I'd have loved to have gone full heat recovery ppv but there was no realistic way to do that without tearing the entire upstairs down 🙁
Having lived in a flat where the landlord deemed dehumidifiers a solution to the issue..... Id move house before I used that solution again. Effing racket , go away for the weekend and the dehumidifiers filled and return to that musty damp smell ... No thanks
Posted : 29/09/2024 3:09 pm
On the back of the info' from this fantastic forum ordered a Meaco DDL8. Ran it since Tuesday, just got humidity down to fifty percent (two bed ground flooor maisonette). Wish id got a humidity meter at the start to get an initial reading (ThermoPro TP65C is great). Yes, it's a little expensive to run. About a £1 a day, but the heating hasn't been on so a save there. And the best news the damp / condensation has just about disappeared. Happy with that. A lot quieter than the old compressor type, lighter too.
Posted : 03/10/2024 9:41 pm
fruitbat, pondo and fruitbat reacted
Compressor dehumidifiers are very relevant and probably more efficient for your use case [if you'd read the Meaco info linked above!]
Posted : 03/10/2024 11:24 pm
A dehumidifier will possibly just mask the issue. In a solid stone building damp on the inside of the walls doesn’t come in from outside, unless your gutters or pointing are shagged, it runs from the inside out over, water vapour from breath, cooking, washing & bathrooms condensing on the first cold surface it finds. If you’ve added insulation to the wall, not provided a vapour barrier surface or not fastidiously sealed it, you’ll end up with interstitial condensation between the new warm wall and the old cold one and potentially damp where you’ve got any bridging.
When establishing a vapour barrier, you have to be obsessive patching every nick, indentation or crack in kingspan’s barrier surface. Socket backings also need taping with foil tape, sealing cable openings and screw holes.
We’ve done this so well in our new kitchen that we get CO2 alerts if the extractor isn’t run on very low when we’ve got people over. We’ve a pair of MrXBox MHRVUs to go in the loft to provide ventilation to the house. They’ll be installed in the coming months but for now the extractor works fine.
Posted : 03/10/2024 11:54 pm
They do work, and are arguably more efficient at heating than a lot of options because they emit substantially more heat than they use electricity.
But it takes a fairly big dehumidifier to do even a small job.  They're best for small, sealed, unheated spaces, like boats left over the winter.
When it comes to keeping a house dry, you've got easy access to dry air (the outside world, cold air holds very little moisture) and heating.  So a better option is probably to just circulate some air from outside, then warm it up.
To put some numbers to that, lets say the house has a volume of 300m3
at 21C and 100% RH (say you've just cooked some pasta), that's about 5.5kg of water.
At 5C it's 1.8kg.
So just opening a couple of windows for a minute to fill the house with fresh air will remove 3.7kg of water.
It takes ~135kJ to heat that air back up again, or 0.04kWh.
TL:DR I have a dehumidifier in my gym-shed over the winter months to deal with the moisture when I'm not in there.  When I am in there I just open the windows.  Having said that, a reasonably efficient dehumidifier is probably as cost effective at heating as gas/oil and better than electric, so may well pay back over a few winters anyway.
Desiccant - works well in the cold (i.e. a shed / boat / garage) , expensive to run.
Compressor - works best at room temp, cheapest to run
I've got the DBBL8 in the shed on a timer, it comes on a couple of hours a day time just before I intend to use it to take the edge off the chill so it's doing two jobs in one.
Posted : 04/10/2024 10:21 am
thegeneralist, leffeboy, leffeboy and 1 people reacted
I got a Meaco 'Zambezi' dessicant dehumidifier about 10 days ago for the garage. It's detached from the house, single skin breeze block + render. Unheated.  Pitched roof + felted, but no insulation and the rafters are open to use as storage.
A few days before getting it, stuff was covered in condensation in there.  Even despite the new insulated sectional door (which had made things a better in there- not hermetically sealed by any means, but a whole lot better).
Anyway- the drier is on the lowest setting, but constant.  I'm defo having to empty the (3 litre I think) bucket every day.
It is distinctly better in there since starting to use it - even Mrs came in when I was doing something and commented on how it didn't feel as damp. And no condensation even after having the door open yesterday for a while.
I've taken a view that the £200 or so quid to run it for several months is worth it to prevent things going moldy, the steel bike getting and corrosion, and not to have the tool chests and tools start to rot.
Posted : 03/12/2024 12:26 am
We suffer a bit from damp in our 50’s end of terrace. It’s been particularly bad this year in the damp Thames Valley.
Drying clothes inside causes issues pretty quickly, also issues from showering.
In the bathroom I have a humidistat controlled extract fan  and open windows when possible.
We found Black mould in a bedroom cupboard, so we removed the wall paper in that area and treated with white vinegar then bleach.
We have since bought a couple of  12l Deawoo compressor Dehumidifiers, which we ran for a day initially. Now we just run them after showers, when clothes drying or just high humidity levels in the house. When opening a window doesn’t help.
Posted : 03/12/2024 5:46 am
hexhamstu, chakaping, chakaping and 1 people reacted
I've put my compressor Meaco on a wi-fi plug in our bedroom now and it runs every day from 9 am to 4 pm.
It uses 800w a day.
Posted : 03/12/2024 8:17 am
jamesoz and jamesoz reacted
I have this each year when the temperature swings, first time in gets proper cold it looks like its rained in my garage, leave the door open for the day and it dries and wont occur again till this time next year.
Posted : 03/12/2024 5:57 pm
It's when it gets cold for a while and then very mild.... The moisture in the milder air condenses on the [still] cold surfaces.
Posted : 03/12/2024 6:48 pm
robertajobb reacted
Anyway- the drier is on the lowest setting, but constant. I’m defo having to empty the (3 litre I think) bucket every day.
Because, unless it's reasonably sealed, its just going to be constantly sucking moisture out of the atmosphere!
Posted : 03/12/2024 6:56 pm
Yep.
It's reasonably sealed *for a garage* - but it's still a garage !  I'm just accepting the £200 or so running cost though to Easter is worth it for non-rotten, non-moldy tools and gear !
Posted : 03/12/2024 8:48 pm
We got a Maeco Zambezi last autumn for our 20s semi and the nicest benefit is zero slugs. Does feel dryer, no longer putting mildly-damp clothes on in the morning, can feel the mild difference in temperature upstairs with the dehumidifier running, and unexpectedly all the slugs have ****** off, which is a great fringe benefit. You'd regularly find the little buggers crawling all around downstairs, or see the slimy trails of their movements - it stopped overnight with the dehumidifier. Awesome. 🙂
Posted : 09/02/2025 11:01 pm
 Mark
Level: Black
Another happy Maeco users here
Posted : 09/02/2025 11:41 pm
If you can open the windows or doors front and back and get the air to draw through every day for five mins, this will give the humidifier a good start.
karcher window vac also gets rid of condensation easily.
Posted : 10/02/2025 6:36 am
Mark reacted
 MSP
We went PPV.
What's a PPV, google doesn't give me anything meaningful, can you link to what you used?
Posted : 10/02/2025 10:30 am
Mark reacted
I presume they meant PIV positive input ventilation
Posted : 10/02/2025 10:54 am
I have been using a 20L Dehumidifier in our bedroom which suffers from damp for a year or so. Has hugely helped, along with regular gutter clearance-blocked gutters meant walls were damp outside 24/7.
I have 2 commercial units running to dry an  elderly relatives empty house that had a water leak. They have been amazing...about £400 on Amazon each.... I'll be selling them soon, but it was way cheaper to buy and run for a month than rent..
Posted : 10/02/2025 11:12 am
https://www.vent-axia.com/positive-input-ventilation-piv
4w an hour in normal use and 500w when heater is on but We don't tend to use that.
Posted : 10/02/2025 6:57 pm
