Another weekend DIY...
[Closed] Another weekend DIY thread - hinges for cupboard doors?
2 Users
Help me out please people.
I've built a fitted workbench in the garage and want to put doors on the front and use it as storage.
The doors (2 pairs) are going to be in the same 18mm MDF as the worktops, and each will be roughly 3' by 2'. I want them to sit "on top of" the frame, rather than "in" it, if you see what I mean.
Are a pair of [url= http://www.ebay.co.uk/itm/5-PAIRS-OF-BRASS-FINIAL-HINGES-50mm-2-Fancy-Cranked-Flush-Kitchen-Door-Fixing-/201562218207?hash=item2eee0b5edf:g:qmAAAOSw~oFXDgZZ ]2in cranked flush hinges[/url] on each door going to be strong enough?
Thank you, people.
Posted : 07/01/2017 1:02 pm
Yep
Posted : 07/01/2017 1:47 pm
That's all I needed to know!
Thank you, internet person 🙂
Posted : 07/01/2017 1:53 pm
HTH 😆
Just use some decent length screws when you put them on
Posted : 07/01/2017 1:57 pm
Can't be more than 15mm on the doors - they're only 18mm thick.
Posted : 07/01/2017 3:00 pm
Does the bit with the 2 slotted holes screw to the end of the door (I.e the 18mm wide bit ?)
( never used the m myself but that was what I was assuming)
Don't forget to pilot drill screw holes in MDF or it may split
Posted : 07/01/2017 3:24 pm
