why hope phenolic p...
[Closed] why hope phenolic piston doesn't fit my mono mini caliper?
6 Users
exactly that. original HBSP117 piston doesn't fit into the caliper cylinder. but why? anyone can help?
thanks
Posted : 14/04/2010 7:32 pm
is it that is doesn't fit or that it is a very tight fit and needs to be exactly lined up?
Posted : 14/04/2010 7:35 pm
well, I didn't use calipers to measure, but it just was too big in diameter to slide it into the caliper body.
Posted : 14/04/2010 7:39 pm
your hammer isn't up to the job
yes, I used only small hammer 😉
Posted : 14/04/2010 7:40 pm
At a guess, I'd say that you've been given a V2, X2 or Mono Trials piston. If it's not the same size as a Mono Mini caliper bore, then it's not a Mono Mini piston.
Posted : 14/04/2010 8:11 pm
Just measured one for you, should be 20.5mm dia., if yours isn't then I'd guess you've got the wrong one.
Posted : 14/04/2010 8:29 pm
cheers guys
will check with calipers tmrw
Posted : 14/04/2010 9:16 pm
service@hopetech.com
Posted : 15/04/2010 10:56 am
