As above, i've looked online but can't find them?
Im probably just being useless.
Cheers for any help.
I avoid CRC like the plague, warrenty returns dept is completly useless. Wiggle are excellent.
http://www.wiggle.co.uk/p/cycle/7/MPart_Torx_Rotor_Mount_Kit/5300005194/
Or if you meant a 6 bolt disc to a Shimano centrelock hub then here:
http://www.chainreactioncycles.com/Models.aspx?ModelID=10262
no i need just the bolts that fit the rotor to a standard deore hub.
I didn't get any with the brake set i bought.
bike shop?
should have got the bolts though with the brake unless second hand or OE cheapskate online retailer.
yeah second hand.
Thought the lbs might charge me an arm and a leg for some.
I can't imagine why you might ever possibly need to return a set of rotor bolts as a warrantee claim!
nothing wrong with crc IME, especially for simple stuff like that. wiggle are very good though, also.
And Wiggle give you jellies 😀
Even halfords stock these bolts......
