what grease for sea...
[Closed] what grease for seat post?
5 Users
alu post, steel frame. thanks. 🙂
Posted : 14/11/2011 11:41 am
Finish line Assembly Paste if it's not going to be moved very often as it allows relly low clamping pressures, or just a light smear of any grease replenished every so often if its going to be raised/lowered.
Posted : 14/11/2011 11:44 am
nice one, thanks. lithium grease from homebase ok?
Posted : 14/11/2011 11:49 am
copperslip???
Posted : 14/11/2011 12:28 pm
 loum
i used park anti sieze once.
don't make that mistake, collects a horrible sticky layer of muck.
use a light grease thats easy to wipe off the exposed bits of seat tube.
Posted : 14/11/2011 1:17 pm
Probably yep, I use the cheep Coma stuff from halfords, just remember to take it out and give it a wipe and poke take the seatpost out of the frame to let it dry after a wet ride.
Posted : 14/11/2011 1:24 pm
I'm using the carlube lithium grease and it's fine, if you get any slippage just use any a small bit of chalk to help grip it.
Posted : 14/11/2011 1:35 pm
