Is it possible to tweak the ProPedal on an Fox RP2? I'm still finding that I get a lot of pedal bob when climing in the saddle - I'm a bit of a bloater, not sure if that affects the performance of the ProPedal?
There is a single ProPedal setting on the RP2, on or off, whereas the RP23 you can choose one of 3 settings that are engaged.
Before I take the plunge and just go out and buy an RP23, I was wondering if it's possible to adjust somehow the single propedal setting on the RP2, perhaps there's some sort of adjustment screw hiding inside somewhere?
Send it to Tim and he'll square you away no doubt.
Contact Mojo on 01633615815, they'll be able to tell you what's possible. I believe it's controlled by a shim stack, if i'm right they should be able to tune it to suit.
