Just the right length wires and size pad, heats up to about 35C max.
https://www.ebay.de/itm/USB-Electric-Heating-Vest-Jacket-Pads-for-DIY-Heated-Thermal-Clothing/254779840203?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 (you can find them from Chinese sellers for £3)
Had a usb powerbank lying around and found these - doesn't get easier, although it does not go into the fingers it helps heat the blood going to them so if you're just missing a bit of heating they should do the trick.
Chinese sellers you say? Maybe a fire extinguisher in the other pocket also 🔥😄
Out of interest, I've got a powerbank that has a heat mode built in. I don't trust it though, plus it's draining the battery and I need it for charging 😁
35C is not enough to catch fire - it's just two wires connected to a graphite cloth - powerbanks have short circuit protection too so I wouldn't worry.
Could they fit in a shoe? whats the length of the cable before it joins together?
Excellent stuff 🙂
@robbie each wire from the usb plug to the start of the pad is 115 cm.
I bought something similar for a fiver on amazon that were longer and thinner for shoes.
I've put them on the drop bars on the back of the tandem for my daughter. Threaded a pair of old socks over and held on with elastic bands. Seems to work a treat but blitzed a battery faster than my wahoo would!
I also got a five patch set up that comes with an on/off hi/lo setting switch that I'll work into a gilet at some point.
Saying item won’t be sent to United Kingdom
@hainman Chinese seller: https://www.ebay.de/itm/USB-Electric-Heating-Vest-Jacket-Pads-for-DIY-Heated-Thermal-Clothing-NEW/143907006671?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20200520130048%26meid%3D8741a1ffc3f948eb9046e08f61777528%26pid%3D100005%26rk%3D2%26rkt%3D12%26mehot%3Dco%26sd%3D254779840203%26itm%3D143907006671%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv5PairwiseWebWithDarwoV3BBEV2b%26brand%3D%21it&_trksid=p2047675.c100005.m1851
There are a bunch
@johnnystorm yes seems to go through battery fast, will try to measure how much running time I get from a 40Wh one..in theory i should get 2 hours (5V * 3A max output so 15W).
<cough>pogies<\cough>
Oh yeah, I have pogies on the back for my little 'un too.
So this is the 21st century version of a bit of string running up your sleeves and keeping your mittens together?
Did some testing, seems they only draw 2A at 5V so 10 watts, a small 180g 10000 mah / 40 Wh powerbank will then give up to 4 hours runtime - not bad! Temperature the pad reaches averages around 35C like stated.
Got some, work great. Ordered a USB switch so I can turn off/on as needed. Not sure how the wire config will work with it
Like this, but 1/3rd of the price on ebay
https://www.amazon.co.uk/gp/product/B07S7C27PD
Anyone used these on the bike,trails yet
Mine came today and I’ve plugged it in to test and does generate some heat but how it would have held up the other morning when it was minus 3 and I couldn’t feel my braking finger would have been good to test
Like the look of that switch
Might grab one to add to it
Mine (singluar) arrived today. Just one pad in a package with a Y splitter and 2 plugs. It gobbled the juice out a powerbank in a couple of hours plugged into the 2A output. The temp read at 50 degC. I wonder if it would throttle back the current and temp plugged into the 1A output?
It's spring now.... was a great idea 3 weeks ago, but it's toasty now 😀
Aye Mibbe in the rest of the world but up here in Scotland even our summer is f@ckin baltic
Happy to hear it worked, here in Germany it got too snowy to ride by some miracle..
Review here
Would this not work of a mobile phone?
It was t-shirt weather yesterday in peebles.
Awright for some
I’d give my left nut to get to ride down peddles area again soon
