Torque Wrenches — A...
[Closed] Torque Wrenches — Are they necessary?
50 Users
So, there is a short back-story to why I'm asking this. Simply put, there is a creaking coming from the front of my Inbred, and it makes me nervous. I have a RaceFace Ride XC Stem, NukeProof warhead bars, OnOne Smoothie headset, and a carbon X-Lite fork (which has a carbon steerer on it). It's all held together with some FSA thing which seems to work like a Hope Head Doctor.
Now, for love nor money I can't figure out why it is creaking, but it makes me nervous when I start to notice it riding singletrack. I've started to wonder if it boils down to have the wrong bolt torques, I don't want to over tighten the bolt and damage the fork steerer. The thought of a fork failure scares me no-end.
Am I being paranoid over nothing? If I do get one, how do I know what to torque the bolts to? I bought the fork second-hand but like-new from the classifieds.
Also, if I do get one, what would you all recommend?
Posted : 07/12/2013 9:49 pm
No, not on bikes. They're mainly there to prevent people from over tightening steel screws/bolts into Alloy components. With a bit of care and feel you can tighten things up perfectly fine without. If you're worried then you can always give things a bit of a check after a few rides to be sure they're not coming undone - probably good practice anyway.
edit - on the creaking have you tried a squirt of WD40 in the area you're suspicious of? I doubt the 'wrong toque' is causing it unless its too loose, which you'll be having other issues too. You could always give things a bit more of a nip up to be sure.
Posted : 07/12/2013 10:02 pm
no
Posted : 07/12/2013 10:03 pm
 JAG
For balance....
I'm a professional Engineer and I can confirm that the torques specified for bolts on your bike are there for a reason. Those torque values are the best/only way for us Engineers to be sure that the bolts are tight enough/not over-tightened.
We take into account the material of the parts being fixed together (Yield strength etc...), the bolt material, the head size and the likely compression of the parts in the joint.
We calculate the bolt torque to give sufficient clamp load to hold the joint together. We consider the head diameter of the bolts - to check that the head won't compress the parts being fixed and thus lose tension from the joint. We consider the vibration and all external loading on every fastener and joint and all this to ensure that once tightened it won't come loose.
IF the joints are tightened under our control we even loosen some to check that we get a minimum torque on a statistically significant number of joints. We plot these values on a graph and watch the trends too!
Based on all of that hard work - please feel free to nip them up as tight as you think is reasonable and don't waste your money on a Torque Wrench 😀 8)
Posted : 07/12/2013 10:16 pm
Whatever the FSA thing is, it's not holding it all together, it's. The stem clamped to the steerer is holding it all together.
If your'e unsure & haven't got a feel for 'tightness' 😆
Then use one.
If your'e an old school fitter like me & a fair few on here, you probably don't really need one.
Posted : 07/12/2013 10:21 pm
Split the difference....They're functionally useless for general spannering, but if you have a persistent creak then you have to drag one out and verify the torque spec.
A creak is always going to have multiple possible causes. Knowing that the bolts are done right is an important step in sorting it out.
As far as torque wrenches go I wouldn't recommend the one I have just because I have no idea how accurately calibrated it is [because it sits in the tool box for years at a stretch]. One that can be calibrated and adjusted accordingly sounds like a good idea.
Posted : 07/12/2013 10:28 pm
5 knuckles tight on everything never failed me 😯 well only once 😉
They are certainly helpful. Having said that most likely culprit for squeaky is dry joints, so a bit of grease or copper slip prob best way to sort it. We prep race bikes here so always using torque wrenches and often use them on cycles but most of the bolts, on cycles, that we have had problems with have been where we used a torque wrench so I reckon many of the recommended figures are too high. Always remember to grease a bolt before torquing to get the right setting or where appropriate (ie rotor bolts, chain ring bolts etc..) use lock tight both to lube the thread when tightened and lock it once done.
Posted : 07/12/2013 10:33 pm
If you want to do the job properly, then I think you should use one.
Few people could set up the pivots on a FS for example, unless they did it very often.
Posted : 07/12/2013 10:38 pm
Usefull but only if calibrated properly. Ours at work used to be done every 6 months. But now we have to check the torque before every use on the analyser. Mainly due to people dropping them and mistreatment
Posted : 07/12/2013 10:42 pm
yes you need one for softer metal parts you don't want to rip to shreds...
Posted : 07/12/2013 10:43 pm
I've been using a Norbar torque wrench for years now, just for piece-of-mind.
I sell carbide cutting tools for a living and we always recommend to our customers to use a torque driver for tightening tool screws, the difference from engineer to engineer on how tight something should be is vast. Sometimes the insert/screws have come loose due to over tightening (stretched threads)
Posted : 07/12/2013 10:52 pm
Genius couple of answers up there from JAG, (an engineer explaining the critical calculations made in designing a joint) then 2 replies later, esselgruntfuttock a time served fitter, (just whangs it up as tight as he feels). Ace. 😆
Posted : 07/12/2013 11:01 pm
 deft
Wiggle have a Ritchey torque wrench for £15 that is set to 5NM for stem bolts. Bit of a compromise if cost is an issue?
Posted : 07/12/2013 11:06 pm
I think easel meant that after a while you can closely estimate a torque value. I reckon I could give you within 5nm.
Posted : 07/12/2013 11:08 pm
Well OK, but I'm not sure I believe you, (and I'm more of a whanger for anything over an M6, and a mechanical engineer to boot).
Posted : 07/12/2013 11:14 pm
 Andy
I have just spent the afternoon building a bike for and with my nephew, and his new torque wrench, and after every bolt tightened I heave heard "HOLD ON LETS SEE WHAT THE CORRECT TORQUE IS FOR THAT BOLT! Oh its done up correctly". Its been a funny afternoon though 😀
So for the inexperienced yes. For the professional who is liable for their work yes. For those with experience maybe not.
NB I was taught by my old man (who died in '97) how to do it.
Posted : 07/12/2013 11:25 pm
I'm amazed at the variety of answers! JAG has it, Essel - I kinda know where you're coming from. When I was a full time mechanic, I gained a 'feel' for certain and most often used torque values but would always check them with a calibrated torque wrench - backing off and re-tightening in sequence if I had pinched up too tight.
I find my FS works much better when the pivots are at the correct torque value too 🙂
Why compromise expensive parts or a frame, or your own safety and peace of mind are further reasons for following values and sequences. 😕
Posted : 07/12/2013 11:34 pm
Most bike parts aren't space ships - they're steel bolts into steel or alu. So if you've got no feel for torque and tightness, sure - they're a good idea. But the only time I use one is the special 1.1Nm 1.5mm Allen key I use for tightening the tiny grub screw in a Schlumpf drive.
A badly calibrated torque wrench is worse than none at all. In my experience, the most accurate torque wrenches that don't cost a mint are the old-fashioned bending-beam type.
Posted : 07/12/2013 11:37 pm
[i]I think easel meant that after a while you can closely estimate a torque value. I reckon I could give you within 5nm.[/i]
Ha ha, brilliant! I have a torque wrench & the last time I used it was on some Race Face cranks onto an Isis BB (32nm?) The last time before that was on a Diesel Sierra cylinder head (it was in ft/lbs & can't remember what it was!) but anyway, since then I've stripped nowt, & nowts come loose!
Posted : 07/12/2013 11:46 pm
My main gripe with torque wrenches is.
Which value to take..... That of the stem - that of the bars ? ThAt on the collar , that of the seat poat ?
Certain items have a torque value on the, thatcserves nothing more than as a warrenty get out clause- ritchey im looking at you with your 5nm seatpost clamp torque.
I have a torque wrench at work - it goes to about the region of 50k ftlbs for the stuff i do but can go faster 🙂
Posted : 07/12/2013 11:57 pm
I read somewhere that even experienced mechanics, when asked to do a bolt up to 5nm, varied wildly with some out by a factor of 2 - both too tight and too loose.
I've got one of those ritchey 5nm torque things. Assuming its accurate, I've been under-tightening bolts for a long time! Never had any problems though.
Your creak is probably not bolt torque. Take the front end apart and clean everything well. Put it back together and sometimes that'll cure it.
Posted : 08/12/2013 12:05 am
Torque to what's being clamped onto. E.g. bars or seat post. Imagine you've got a carbon bar that's torque to 4nm, and the stem says 10nm, you're likely to crack the carbon if you go to the stem spec.
Posted : 08/12/2013 12:08 am
Unless you also specify temperature and lubricant to use, specifying just the torque is a bit pointless anyway. 5Nm with Teflon grease is a lot tighter than 5Nm unlubricated.
Posted : 08/12/2013 12:09 am
Creak is likely to be, headset bearings dry, bearings in the cup dry apor dirty, steerer coming loose, stem bolts dry.
Like above, unlikely to be torque, unless you've cracked the steerer or bars, which you'll see easily.
Disassemble and clean, grease, reassemble.
Posted : 08/12/2013 12:13 am
I had a similar problem and eventually traced it back to the brake cable outer going into the housing on the top tube. Some light grease every so often stoped the noise
Posted : 08/12/2013 7:09 am
OP, if your fork has QR dropouts, check that the skewer is tight.
Posted : 08/12/2013 7:15 am
Rickon very good but clamping force is proportional to area
Thin faceplate 2 bolt stem exert more clamping point load force to bar than a 4 bolt wide face plate stem . How can you then give a bar - a non threaded item a torque - as i said sometimes there purely to cover manufacturers arses. And you need to think about it more than just blindly following a torque value given as ive yet to see a proper torque specification on a bit - its just a number normally - as ben says lubricant makes all the difference.
Posted : 08/12/2013 8:39 am
You're quite correct in theory. In practice, some combinations just don't hold and play will always develop. The right Loctite can help in those circumstances.
Posted : 08/12/2013 8:45 am
I'm rather surprised then that you didn't mention the importance of regular calibration.
If you're not doing that (and I'm yet to meet an mtber who does though no doubt stw will provide one) then it's a pretty pointless exercise particular given people's propensity for dropping tools, etc. Not to mention the other factors mentioned above eg lube, temperature.
Posted : 08/12/2013 8:47 am
 br
I thought you shouldn't use expanding devices (like a Head Doctor) with a carbon steerer?
Posted : 08/12/2013 8:55 am
That's exactly the sort of device you should use for carbon...
Posted : 08/12/2013 8:58 am
Had a similar issue with my XT cranks - always had an annoying creak but was really worried about over-tightening the bolt on the non- driveside arm.
Borrowed a torque wrench from a mate, nipped it up, problem solved.
I'm going to get one - worth it just for the peace of mind and to reduce the amount of time faffing with trial-&-error type solutions
Posted : 08/12/2013 9:17 am
I recently bought an Icetoolz torque wrench from Halfords to build the new carbon road bike.
To spend hundreds of pounds on lightweight carbon parts, then take a guess at how tight to do the bolts up for the sake of £25 seems a bit silly.
That said. After checking the torque on the bolts of other bikes in my garage. They were all done up well below the recommended Nm.
Posted : 08/12/2013 9:33 am
Your asking the wrong question. You're asking us to determine your risk appetite and only you can answer that.
Every home mechanic, by skill or good fortune, on here has tightened bolts enough so they don't loosen or break... They say as much above.
Every engineer is taught that torque is important, and of course in many applications it is, it can be life and death.
I've been riding, home mechanic 20 years and went with the home mechanic view for about 18 years, then under tightened a stem bolt resulting in the carbon bars twisting on a trail, taking a tumble, breaking two ribs. You'd think this would make me say I now am onside with the engineers... I'm not. I sit firmly on the fence. Most of the time I still trust my fingers to get it right but at the end of the job I do now check torque.
It's your risk appetite!
Posted : 08/12/2013 9:49 am
If you have fifty quid needing a new home then go pick one up.
I have one and use it all the time but did just fine without it. No stripped threads and no components coming loose on the trail.
Posted : 08/12/2013 9:53 am
http://www.enerpac.com/en/torque-tightening
Posted : 08/12/2013 9:55 am
Indeed i would say they are most important when it comes to carbon, your more likely to under tighten carbon for fear of breaking it and thats where the problem will come. Try this its basic but cheap [url= http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_categoryId_242558_productId_920043_langId_-1?istCompanyId=b8708c57-7a02-4cf6-b2c0-dc36b54a327e&istItemId=xtapwlmrw&istBid=tztx&_$$ja=cgid:5302137724%7Ctsid:35522%7Ccid:119462284%7Clid:18283950120%7Cnw:search%7Ccrid:21270118204%7Cdvc:c%7Cadp:1o1%7Cbku:1&gclid=CJOtzteyoLsCFafnwgod_AYAwQ ]Topeak Torque Wrench[/url]
Posted : 08/12/2013 10:18 am
From what I have read elsewhere the importance of the correct torque setting has come from the use of carbon parts. Whilst over-tightening of anything has its own problems, I have seen some crushing of very expensive parts, especially handlebars, due to over-tightening.
Posted : 08/12/2013 10:19 am
Uhuh.
This is what happens on bikes.
The Guy who has to write the guff on how to use the component asks the guy who designed the component what torque a bolt needs to be done to. He asks this question because he's noticed all the other companies have these numbers so feels he should add them too.
The guy who designed it then responds in one of two ways, he either makes up a number that sounds about right, or he gets a torque wrench and does the bolt up to what feels right and notes the reading.
Posted : 08/12/2013 10:23 am
Fresh, clean threads, clean surfaces, correct preperation , yes, torque values are very relevant.
Take bike parts which are dirty, corroded, I'll prepped, distorted, out of tolerance, torques are certainly no longer representative of applied loads.
Torque values certainly have their place on manufacturing lines and in industry, I just don't feel they're anywhere near as relevant on a bike.
Ianmunro sounds to have it spot on though.
Posted : 08/12/2013 10:32 am
So how often do these torque wrench users get their wrenches calibrated?
Posted : 08/12/2013 10:38 am
ti_pin_man
Every mechanic is taught that torque is important
Every engineer is taught that fastener/joint strain is important
EFA^^^ 😉
But no, you don't need a torque wrench for a bike generally speaking. Very few fasteners will be absolutely "torque critical" and none will be torqued to yield. Yes, you need some measure of 'feel' while you tighten any given fastener, and a general appreciation that an M4 SCH should not be tightened as much as an M8 SCH etc!
My experience of low cost torque wrenches, especially ones used to tighten bolts to low absolute torque values (<20nm) is that they are generally highly inaccurate, and how the operator holds and uses them can be critical too (especially for the "clicky" type)
Posted : 08/12/2013 10:54 am
Tough one, I think few in the bike trade used a torque wrench for decades.
I can see some potential merit for light/fragile/critical parts like carbon stem face plates or similar, but as said above, most of us can tighten a bolt to hold something on without damaging it with experience.
My suspicion is it's something that's been imported into the bike world to sell us more tools and make stuff sound more technical.
Posted : 08/12/2013 10:57 am
I thought the "torque settings" on MTB components are there so that manufacturers have a get out of jail free on warranty claims.
Posted : 08/12/2013 11:00 am
ChunkyMTB - Member
Standard torque wrenches/drivers are a 12 month calibration in my line of work.
Posted : 08/12/2013 11:12 am
nickc - Member
...and sadly that's all too necessary if you'd seen the number of trashed components they get back because some people aren't capable of tightening anything up without using a 3 foot-long extension bar.
I worked alongside a major U.K. warranty department for 3 years and the vast majority of snapped bars, seatposts, brake or shifter lever clamps, steerers and saddle rails were clear cases of people massively over tightening the respective clamps.
A component manufacturer has two options if they want to avoid being sued:
A: Make their components largely immune to cack-handed assembly by hugely over-building them and making a loose bolt or two less important (6-bolt handlebar clamps etc). And then watch their sales plummet.
B: Stipulate torque settings, those with a bit of common sense won't need them but it prevents the manufacturer being liable for idiots who should never be allowed near a tool kit.
It's no coincidence that recommended torque settings have emerged in line with the trend for people buying high-end components mailorder and fitting them at home.
Posted : 08/12/2013 11:35 am
Oh, and regarding recalibrating torque wrenches, if you have a decent one, store it carefully, reset it to zero before you put it away and don't drop it then it'll go for years without needing calibrating.
If you have a cheap one, use it frequently and treat it rough then it's going to need much more TLC.
Posted : 08/12/2013 11:37 am
Torque wrenches are very relevant, especially if your boss used to work on harriers. He is banned from screwing anything up! In honor of him we have a unit of Torque named after him called a "Spellman" (c). It is precisely defined as the point you feel the threads fail be it M3 or M20! 🙁 😀
Posted : 08/12/2013 11:51 am
Well, thats a somewhat bigger response than I was expecting!
It's quite interesting reading everyones replies. I'm not an engineer, so did't realise a torque-wrench would need calibrating, and to be honest didn't think it all through enough to consider thing like the temperature of grease used would effect the readings. These variations lead me to believe that there isn't a huge amount of point in getting one.
I tend to think I'm reasonably sensible with the 'feel' of bolt torque. I've never had anything come undone on the trail. I've never sheered a bolt head or broken a part. The only time I've had something move on the trail was when I rode into a tree 😳 at which point the stem move on the steerer as you'd expect.
Done this several times, no luck. I've had the headset from new too, so I'd doubt it's the bearings.
I'll give this a go, never even though to check if it was cables. Pretty sure it's coming from lower headset cup area though.
15mm axle here, but I did check it wasn't loose.
Posted : 08/12/2013 11:59 am
These are pretty good for bars and stems, I've taken to using one every time now. It's a neat handy tool and you know your 4-bolt faceplate or 2 bolt stem is perfectly evenly tightened. Other than that the only time I get a torque wrench out is for cassettes with ally spiders
Should probably recognise the logo, but who makes that one?
Posted : 08/12/2013 12:39 pm
Not strictly, and yep: calibration is a consideration especially if you drop it, lewt others use it, keep it in the shed or forget to zero it after use.
My twopennorth': I've seen too many mates end up with wrecked things because it turned out that 'yorkshire tight' was too much.
Unless you go crazy and buy a super expensive one (£20 gives you a choice), the first time something snaps and you have a major job of cutting slots and stuff as a result may be the time you see the benefits. Sure the £20 option is unlikely to be cock on but it may be a better guessing stick than your tendons.
I personally bought a small bike size one after accidentally pinging a steerer cap bolt and not having a spare (although the unsupported forks were probably the real cause) which trashed a couple of rides.
I'd agree that most people tend toward 'way too tight' but I've also been guilty of undertightening. For things like stem faceplates (comments about bar fails above) it's important to tighten crosswise and progressively rather than doing the first one up as tight as you can then starting on the second ...
Overall, I think torque wrenches basically buy peace of mind that things are less likely to fall apart on you, which is nice.
Oh, and unless the instructions SPECIFICALLY say to grease the bolt you're about to torque, don't. You'll end up way tighter than planned as the grease makes the torque wrench into a liar...
Posted : 08/12/2013 1:08 pm
oh, and +1 that the FSA head doctor-alike is your likely creaking problem here unless your faceplate bolts are way too tight/uneven.
Posted : 08/12/2013 1:10 pm
I grease everything - well, everything apart from the things that get threadlock. If you don't grease then (apart from corrosion, galling etc) you've got no standard of stiction, you don't know if the bolt is right because it's tight or because it's stuck.
Posted : 08/12/2013 1:19 pm
 LeeW
When I'm tightening up something I don't want to break I use a torque wrench. It's calibrated (I manage a UKAS stds laboratory) and I know when I'm using it nothing 'should' be over or under tightened.
I don't want to break my expensive bike components so I use my torque wrench/driver. If I was constantly building bikes for a living, I'd probably use it less as I'd get more of a 'feel' for what I was doing.
Posted : 08/12/2013 1:23 pm
That's the thing - I don't use a torque wrench for the same reason I don't use an infrared thermometer when brazing - practice means I've got the feel of it.
If you don't do enough bike spannering to get that feel, then a (decent, well-calibrated) torque wrench is a good idea for piece of mind.
Posted : 08/12/2013 1:26 pm
 LeeW
legend - Member
ChunkyMTB - Member
Depends on how much you use them, in the Aerospace industry where torque settings are critical, some people have stipulated frequencies of anything down to monthly, My main client has a 'Standardised before use' policy, i.e. calibrated against a master.
Though, it does depend on how many you have or how much it costs to calibrate them. (Generally) the more you have, the longer the frequency. *geek* I'm not sure if BS26798 has a recommended frequency and I cba to look *geek*
Posted : 08/12/2013 1:32 pm
It's a bit not simple really. I use a torque wrench very occasionally on the pushbikes, on silly torque-sensitive cranks as I can't accurately judge 50nm. But for everything else I use my torquefingers, which are pretty accurate.
Course, you aquire accurate torquefingers over a lifetime of breaking bolts, stripping threads, and having bits fall off. Getting a torque wrench (or 2) is probably easier.
But then, if you never aquire any sort of torque-sense, it becomes fairly likely that sooner or later something is wrong- a crossthreaded bolt, or a blocked thread, or a too-long bolt, or you just set the wrench wrong or read the torque wrong (or you're reading a Suzuki service manual and a bunch of the settings are mistyped)... and you trust the wrench and then, bad things occur.
Posted : 08/12/2013 1:53 pm
What make is the red wrench up there ^
Posted : 08/12/2013 1:58 pm
Bontrager - Preset Torque Wrench
[url= http://trekbicyclestores.com/product/bontrager-preset-torque-wrench-76318-1.htm ]http://trekbicyclestores.com/product/bontrager-preset-torque-wrench-76318-1.htm[/url]
Posted : 08/12/2013 5:50 pm
Torque wrench when dealing with carbon parts.
Posted : 08/12/2013 7:23 pm
Screws / bolts work due to the balance between friction in the thread and tension between the shank and the head. If you lubricate them, then the friction goes down so the tension must go up. It increases the risk of bolt heads shearing which is potentially more disastrous than if they slip. So, I never grease bolts that shouldn't be greased.
Posted : 08/12/2013 8:28 pm
Bolts should have either antisieze or loctite on.... Pending use, but grease not unless i had absolutely nothing else.
Posted : 08/12/2013 8:31 pm
I did a mini service of my own Fox's.
Everything back together, and as I "zipped up" the last nut on the bottom of the fork using my small palm sized ratchet (much quicker), torque wrench on the side ready for the final click.....
... "ping" snapped aluminium thread rod, and a large bill next time I want them serviced.
In my defense they are 7 year old forks, so who knows how many times that part has been work hardened by flying rocks, but now I'm just justifying my laziness 🙂
Posted : 08/12/2013 8:47 pm
 JAG
I know I gave a very polarised opinion earlier in this thread - it was intentional.
I believe that torque values are very important in my business (car design) and that they save countless problems.
On a bike... it's not so clear cut. I don't use a torque wrench on the smaller stuff. And I don't use one at all unless I feel it's absolutely critical or it coming undone would be a disaster/safety problem. I believe I have some 'feel' for this stuff after spending my whole life fixing cars and building bikes and repairing stuff.
BUT I do know how hard we work to specify the right value - so I'm also conflicted 😯
Posted : 08/12/2013 9:32 pm
Which is quite funny when the only places ive seen a torque wrench being used on a car are fitting the head and nipping wheel bearings.
Different for designing em though.
Posted : 08/12/2013 9:37 pm
I rather enjoy reading the monthly "torque wrench" threads on stw, so many home fettlers and "engineers" with magic fingers in one thread makes for an amusing 5 mins of reading.
For what it's worth (as this is stw - very little indeed) i use a Norbar SLO 1/4" drive at work on customers bikes along with 4nm/5nm/6nm 1/4" bit driver finger torque wrenches by Snap On, i use them every day and if i entrusted my £5k carbon wunda bike to a shop i'd expect them to use one as well, although i personally would never choose to own a plastic bike so i guess that's another discussion/thread entirely, and my torque wrenches do get calibrated at least once a year, i also do a fair bit of vehicle mechanical work as well so i like my tools to do what i expect of them.
Not a week goes by in the shop that i don't get the job of either removing sheared bolts or rounded out Hex heads or re-tapping threads due to customers who are so ham-fisted that i'm surprised they manage to feed themselves without piercing their jugular with a fork at every meal time/opportune moment, some folk may mean well when they attempt a quick tweak or repair but i'd rather they just got on with the business of riding their bike(s). Centering a £200+ stem in a chuck as you attempt to drill out a 6al/4v Ti 4mm bolt that they have managed to cross thread and shear is not a productive use of my time, although i do apply the "stupid tax" on the bill afterwards they're is always the chance that i will not be able to rescue the item and thus feel inadequate and spend the rest of my day in a sulk.
Posted : 08/12/2013 9:57 pm
Hmm.......depends on whom or what garage does the work, although i tend to agree wi you, when i was in the trade i came across some absolutely shocking mechanical ineptitude and ham-fisted use of breaker bar use for everything, which on critical items like suspension/steering bolts or calliper bolts etc was quite frightening sometimes.
Personally i use one on my car, (fully rebuilt mk2 abt golf) and every suspension/steering/drivetrain item nut/bolt/washer etc was replaced for OE or better quality and torqued then a good majority of them have been lockwired for security, i followed the specs coz i'm kinda anal like that but more so that i could have absolute faith in the car when i'm at 10/10ths so to speak, I want to know i can place 100% trust in what i expect of the car........the car is a hoot to drive, however the driver is very fallible and needs constant attention 😉
Posted : 08/12/2013 10:24 pm
