To chain tug or not...
[Closed] To chain tug or not to chain tug
8 Users
I have an IO and one of the little screws that align the wheels has bent so I have taken it off. I am suffering with the chain going stack after every ride and i wondered if the right way to go would be with a chain tug. If u think that this is the right way to go then can u recommend a make and model?
David
Posted : 14/04/2010 12:48 pm
I've got a pair of these on my Inbred.
Do the job
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=34985 ]Chain Tugs[/url]
Posted : 14/04/2010 12:52 pm
another screw might be a better solution (fnaar fnaar etc)
Posted : 14/04/2010 12:57 pm
Where can I get those screws from?
And what are they called?
Posted : 14/04/2010 12:59 pm
Could you not just go to a bolt shop? I'm sure they'll have a bolt that is the right length and fits.
http://www.cromwell.co.uk/browse?page=1
Posted : 14/04/2010 1:14 pm
a surly tuggnut (driveside) is what you want
Posted : 14/04/2010 1:15 pm
Apparently the NDS is under less force than the DS so you could try using the NDS screw till you get a spare.
SJS probs good for this sort of thing.
 Haze
I sheared the drive side screw on my Simple after it became stuck solid - replaced it with a chain-tug and it's been fine since (the non-drive side still has the screw 'tensioner' in)
Posted : 14/04/2010 1:48 pm
yes chaintug. those little screws are not normally man enough on their own - they are just for guidance apparently!
Posted : 14/04/2010 1:51 pm
Hi all i too have a IO anyone using this one or know if it fits ???? [url=www.on-one.co.uk/i/q/FSOOCT/on-one-chaintug]ON ONE CHAIN TUG !![/url]
Posted : 19/04/2010 5:45 pm
