TFT tuned refresh k...
[Closed] TFT tuned refresh kit questions
3 Users
Evening
I serviced my pikes solo air using a tft tunning refresh kit first question
Does the double seal thing bed in it sees a bit sticky to get going.
The oil came in two clear bottles what oil should go in the legs ( just checking if i put the wrong one in.)
thanks
Posted : 03/06/2011 8:32 pm
anyone?
Posted : 05/06/2011 11:20 am
5w oil goes in the damper leg, top of. The 15w oil goes in the lowers, except that they supply their own red coloured lower mix, I think, in the kits. I've always found newly serviced forks ultra-plush, grease on the inside of the wiper seals, fresh oil in the lowers, I'd make sure you've not folded over the lip on the seal when you put it back together. If you have the wrong oil in the damper- top of the MoCo leg - the fork'll feel about as plush as a lump of concrete...
Posted : 05/06/2011 12:15 pm
one is a fork oil the other they call lube i assumed this was for the foam rings?
Posted : 05/06/2011 12:30 pm
it looks like i have put the oils in the wrong way round
looks like i need to strip and redo
Posted : 05/06/2011 1:07 pm
Posted : 05/06/2011 2:23 pm
