SRAM X9 shifters
[Closed] SRAM X9 shifters
10 Users
I have a set of these & recently the upshifter lever on the rear nine doesnt want to return back to its correct position. Does anybody know if they are serviceable. I see you can buy service kits but will this fix this problem. Everything seems fairly normal & clean & they haven't been crashed or damaged in any way. Advice would be much appreciated
Posted : 26/03/2010 10:56 pm
Might be a spring that's popped out of it's retainer? SRAM X0/9 mechs are a pain to repair if this happens.
Posted : 26/03/2010 11:05 pm
Take it apart and have a nosey. They are fairly simple inside. Are you sure you haven't slightly bent the lever and it catches on the release lever on returning. I've noticed this a few times.
I had the exact same problem. LBS said that once they go they are pretty much impossible to fix (maybe porkies) so I ended up with a new shifter unfortunately.
Posted : 26/03/2010 11:44 pm
Don't take it apart...... they are a ****ing nightmare to get beck together unless you've got 6 hands and if you do manage it they never work.
Posted : 26/03/2010 11:57 pm
Just squirt it inside with some squirty stuff. What have you got to loose?
Posted : 27/03/2010 12:07 am
I bought one for a fiver that this had happened to (turned out the spring had popped out) tried for ages to find a way to assemble the thing but it just wouldn't go back together - as said above, you need 6 hands and a lot of luck. I assume there's a fixture or something for assembling them in the factory . . . . . . .
Posted : 27/03/2010 12:35 am
 gamo
Had two do the same recently, one six months old so back to crc
who are returning it to SRAM! The other just over a year so I took
it to bits and had a fiddle, on this one everything seemed to be in the
right place but def not working,noticed that the plate that slides under
the red disc was sticking so removed the black spring guide/retaining
pin by the cable adjuster and regreased then put the pin back in
(used threadlock) and reassembled the shifter and it now seems fine!
I don't no how or why this tightened up but by loosenig a touch seems
to fix it.
Posted : 27/03/2010 7:20 am
I've had it and it can be a simple fix. Take the other shifter apart - very carefully - and note how the springs work as it's easy to re assemble the pod so that the spring is limited.
Posted : 27/03/2010 7:57 am
Are they the older bulkier style x9's which have been re-badged as x7? If so had the same problem with two pairs just took them apart, greased and never happened again.
Posted : 27/03/2010 7:58 am
They are the newer ones without the displays. I've taken them apart before, there is a technique to getting that spring back in which I found on the internet... cant remember what it was thou off the top of my head but I do remember it was simply when I eventually got it right..
I think the stickyness is caused by the flat washer that sits under the lever arm but not sure
Posted : 27/03/2010 9:32 am
