Sram brake mount he...
[Closed] Sram brake mount help.
3 Users
I'm looking to mount a Sram caliper to a Fox 36, running a 200mm caliper.
The fork will take a 180 rotor as standard so need a mount to suit. Had various Hopes for years so a bit behind on the Sram stuff.
Can anyone point me in the right direction? Thanks.
Posted : 18/09/2018 9:56 pm
I’d say 20mm post. I have a 40mm post on my pike with 160mm standard.
Check out the fitment pic
https://www.ebay.co.uk/itm/Sram-Avid-Disc-Brake-Mount-Adapter-Post-to-Post-20mm-180mm-Rotor-Ti-Bolts/183393774273?hash=item2ab31eeac1:g:hV4AAOSwEFFbfeDU
Posted : 19/09/2018 12:42 am
Thanks for that!
After reading the attached info on the link my 2018 Codes are 180 post - 200, standard/non CPS meaning no washers underneath = 20P or 20S.
Posted : 19/09/2018 3:14 pm
I’m not sure the cps washers are required. My self build bronson with pike is without, whilst my mates factory bronson has them.  Both are fine.
Posted : 19/09/2018 3:18 pm
20mm post. You can only buy the spacer kits, crc do them.
You can sometimes buy the oem brackets which look cleaner but you’ll need longer bolts, which you can get in the spacer kit.
Posted : 19/09/2018 3:55 pm
