SLX Shifter - windo...
[Closed] SLX Shifter - window removal
7 Users
I have taken my window off the left shifter to make a space between the shifter and the tech x2 lever - making space for a gravity drop shifter.
This will save me having to mount that outside the brake lever.
Can you buy caps that go on the top of the shifter - where the old window mount was? I have the pdf from shimano that shows this piece but not sure if I can order one separately.
Posted : 01/05/2010 5:31 pm
The caps are clipped to the bit you've just removed!!!
Posted : 01/05/2010 5:33 pm
it should be clipped to the back of the bit you took off.
Posted : 01/05/2010 5:34 pm
Should clipped to the underside of the window you've just removed.
EDIT: **** me I'm slow.
erm nope nothing clipped in there - these came on bike (will that make a difference with them being OEM).
Checked right shifter too no covers clipped on back of window.
Posted : 01/05/2010 5:40 pm
 nuke
Just stick a bit of helicopter tape or similar over the hole...that's what I did.
Posted : 01/05/2010 5:44 pm
well Ive cut the window at the 90deg bend and thats done the job..First bodge job on this bike so far.
Posted : 01/05/2010 5:59 pm
No covers??? That's odd as my last two bikes cames with them (Orange 5 and Lapierre Zesty) and the first thing i do is remove the windows so that i can get the brakes set-up for one finger braking.
Posted : 01/05/2010 6:07 pm
nick - this is on a five.
Posted : 01/05/2010 6:13 pm
Really?
I bought a 2009 5 Pro back in August which came with XT shifters, they had the covers fitted as did the SLX shifters on my Zesty.
Strange....oh well, you got it sorted.
Posted : 01/05/2010 6:27 pm
Sorry, just settle my confused mind, what did you cut?
Posted : 01/05/2010 7:04 pm
