Shimano @ Sram gear...
Shimano @ Sram gear cables the same?
5 Users
2 Reactions
Need to change my internally routed Sram eagle gear cable and I’ve got lots of Shimano so can I use them? Think I read somewhere there is a slight difference in size.
Also can some kind soul point me in the direction of some plastic tube to push over the old cable before I remove it so I can pass the new one back down it. Tia.
Posted : 20/10/2023 2:08 pm
Shimano are 1.2mm
Sram are 1.1mm
Posted : 20/10/2023 2:11 pm
kelvin and kelvin reacted
Thanks, that what I thought. New Sram cable incoming.
Posted : 20/10/2023 2:28 pm
You can use Shimano inner and outer together with SRAM trigger shifters, not a problem.
I read once that you may encounter some minor problems when mixing SRAM and Shimano inners and outers, but not when using the same.
Posted : 20/10/2023 5:02 pm
1.1mm inners make Shimano super smooth
Posted : 20/10/2023 5:06 pm
I just replaced the gear cable on my eagle with shimano as i had it lying around, it's fine so far.
Posted : 20/10/2023 5:43 pm
Thanks chaps. Ordered a sram inner, will keep the Shimano ones for the other bikes.
Posted : 20/10/2023 6:17 pm
