Shimano freewheels ...
[Closed] Shimano freewheels are rubbish
Half way round the Builth Marathon today, found myself powering up a really steep bit in the wrong gear having misjudged it - well, apparently Shimano freewheels can't take the awesome power of my legs, and I mashed the insides, which locked it up.
If I'd been riding a hardtail I'd have removed the rear mech and turned it into a fixie.. but no such luck. Bugger.
Don't buy Shimano hubs kids. Btw this is XTR from 2 years ago.
Posted : 11/04/2010 8:23 pm
quick edit that to freehub before someone pulls you up on it 😉
Posted : 11/04/2010 8:37 pm
Oh dear. Someone behind on their servicing and not even noticed?
Posted : 11/04/2010 8:40 pm
I'm resigned to my fate. Also resigned to the fact that a replacement costs £100...
You what? You have to service freehubs since when?
And the insides are mashed - since when does servicing make the insides stronger?
Posted : 11/04/2010 8:41 pm
£99.99 or £124.99 too!! 😯
Posted : 11/04/2010 8:43 pm
Servicing = replacing parts that wear out.
Posted : 11/04/2010 8:50 pm
I take it you're the bloke that was shouting "Shimano hubs are rubbish" at everyone who rode past you today? I must confess I thought it was slightly strange behaviour! 😉
Posted : 11/04/2010 8:52 pm
Yeah. I've had a Hope axle snap and have exactly the same effect
Shimano freehubs aren't brilliant, but they are no worse than Pro 2 hub bearings......
Posted : 11/04/2010 8:53 pm
Cynic-al - the hub didn't wear out, it failed suddenly.
It'd done all of 1000 miles.
Yes, that was me telling passers by not to buy Shimano hubs - for a few minutes, as a way of venting my spleen 🙂
And PP - when hope bearings fail (after about 2 years for me) they go gradually and don't stop you riding another yard. The axle snapping woudl do that hto 🙂
Posted : 11/04/2010 8:58 pm
Out of 5 Pro 2 hubs that have passed through my garage (3 front, 2 rear) only one had had bearings that lasted over a year. I've just today replaced 2 of the 5 in one rear for the 2nd time.....
When I've had Shimano freehubs give up (several times over the last, ohh, 19 years) they've always given me a few weeks notice by slipping and making odd noises. But then I've never had any better than XT, usually Deore, it has to be said. 🙂
Posted : 11/04/2010 9:03 pm
Sounds like a result of aggressive cleaning to me
Posted : 11/04/2010 9:06 pm
Sudden failure is "wearing out" for freehubs. 1000 miles sounds por tho. Unless you are a friend of muc off
Posted : 11/04/2010 9:10 pm
It didn't start slipping, like they do when full of crud which stops the pawls returning. It suddenly seized i.e. locked in both directions, immediately after I put a lot of torque through it. It was butter smooth and absolutely up until the exact moment it locked.
Failure, not wearing out.
Posted : 12/04/2010 12:01 pm
how do you service a Shimano freehub ? There must be a special tool ?
Posted : 12/04/2010 12:07 pm
I need to hang up my butch credentials. I've never had a shimano hub long enough for it to die on me. I can only think of one or two hubs that I've actually felt the need to service, and they were hope.
Posted : 12/04/2010 12:11 pm
fair enough. I've heard the newer ones (biger axles?) are gash.
Posted : 12/04/2010 12:19 pm
Let me re-iterate. It did not wear out, it failed. As in snap bang boom, unrelated to how old it was or how many miles.
Posted : 12/04/2010 12:21 pm
I never seemed to have much trouble trials-riding on shimano freehubs, but some do.
Can't really say that without forensic analysis of the internals, are you sure it wasn't fatigue of the end of the pawls, or a bearing collapsing causing the whole lot to jam?
Posted : 12/04/2010 12:34 pm
To go from perfect operation to complete seizure in one ten second bout of more torque than is ever normally required indicates sudden failure not wearing out - especially as it's not done many miles.
Some wear may have contributed to failure but that's not the same as wearing out.
Apparently.. spares are unavailable 🙁
Posted : 12/04/2010 12:59 pm
