Shimano 4 pot calip...
[Closed] Shimano 4 pot calipers -what are the main differences?
Got an MT520 on the front which is fantastic so thought i'd get one for the rear BUT then i saw the MT420 which is cheaper and claims to be 90% more powerful??
https://www.deporvillage.net/shimano-mt420-dt-display-resin-disc-brake-black?gclid=Cj0KCQjwzN71BRCOARIsAF8pjfiZVCHcOVbwy8B9J3dkxaFsRN6fK-57YhVNuNE9z1IuXwLVoEcPkkMaAlP-EALw_wcB
https://www.deporvillage.net/shimano-mt520-post-mount-4-pistons-resin-black-disc-brake?gclid=Cj0KCQjwzN71BRCOARIsAF8pjfhOdGXAbI0FAmXzZ_76kmTJBF9-ZllqkvDiA9e6o8skDpuE7Aq99fgaAgizEALw_wcB
do i stick with the MT520 or twist on the MT420??
Posted : 10/05/2020 9:22 pm
Those figures are nonsense - it’s just a cheaper version of the 520.
JP
Posted : 10/05/2020 9:34 pm
Read the Shimano literature - it’s got 90% of the power of the 520, not 90% more!
JP
Posted : 10/05/2020 9:39 pm
Misread - loooooooooong day! MT520 for the rear unless i can find some sram guides with code calipers
Posted : 10/05/2020 9:43 pm
 mboy
What caliper do you have on the rear at the moment? I've got M520's on my Hardtail, front and back. To be honest, a 4pot on the rear is overkill for me on that bike I find, so would consider a PX with a 2 pot caliper for my 4 pot if you've got a 2 pot I could use instead...
Posted : 10/05/2020 10:38 pm
I’ve a 2 pot m520 on the back
Posted : 10/05/2020 10:44 pm
Mt500 even
Posted : 10/05/2020 10:45 pm
As it’s my only bike I’d need it before I could send mine, any problem there?
Posted : 10/05/2020 10:46 pm
Marketing people just making up numbers. WTF does "150% more water resistance" actually mean?
Features:
- 90 % more braking power than BR-MT520
- 20 % more braking power than the current two-piston BR-MT400
- 150 % more water resistance than the current two-piston BR-MT400
- Brake pad: resin, metal
Posted : 11/05/2020 1:14 am
Misread – loooooooooong day! MT520 for the rear unless i can find some sram guides with code calipers
They're called Guide RE. last gen code caliper but work the same give or take.
Posted : 11/05/2020 6:55 am
Whereas 13.5/14st of me thinks that Deore MT520 4-pot with Kevlar pads are the absolute shizzle and make me realise how underpowered my old two pot 500's were. I used to have issues with glazing over on some bigger descents, not any more.
Posted : 11/05/2020 9:13 am
what's the cheapest 4 pot caliper with banjo fitting? Anyone know? SLX?
Posted : 11/05/2020 11:13 am
ive had great luck picking up zees for 70-80 per end...
Posted : 11/05/2020 11:37 am
