Iv brought a scandal 26 18in frame to build up from scratch. I think iv Found some forks that are right but the steerer is cut to 193mm. should this be long enough?
Posted : 29/12/2012 5:03 pm
18in frame has 105mm headtube.
Headset = 40mm?
Stem = 50mm?
Sounds fine.
Posted : 29/12/2012 5:04 pm
Yep...eg 35mm headset, 40mm Stem, 105mm HT = 175mm
@edit Blimey, Brants sitting ready and primed to answer any O-O related questions 😯
Posted : 29/12/2012 5:05 pm
My Inbred has same length headtube and with 210mm steerer. I've got 48mm spacers + stem so you'll have plenty of space.
edit: You have a Horses Mouth answer in the time it's taken to measure.
Posted : 29/12/2012 5:09 pm
cool thanks, so most run without spacers below the stem?
Posted : 29/12/2012 5:32 pm
