rear mech adjustmen...
[Closed] rear mech adjustment help
5 Users
The chain on my giant glory has gone slack. It happened a few months ago and when i took it to a mechanic he said he just had to adjust one of the screws on the rear mech (shimano zee) and it was sorted. After a few months its happened again but I can't remember what I need to adjust or which way to adjust it
Any help you can offer will be gratefully received
cheers
james
Posted : 06/10/2019 1:16 pm
It'll have been the B-tension screw that he adjusted, but once it's done, it shouldn't really need doing again. I'd check that the pivot that the cage rotates on hasn't seized up.
Posted : 06/10/2019 1:43 pm
excellent cheers
Posted : 06/10/2019 1:55 pm
Check that the mech hasn't become disengaged from the stop on the frame - the lug on the rear mech can break / get bent. If you twist the tech anti-clockwise around the mounting screw / pivot does it spring back? Not unknown for the torsion spring to break / corrode - in most cases the rear mech is toast.
Posted : 06/10/2019 2:40 pm
 PJay
Something jammed or grindy in the clutch perhaps?
Posted : 07/10/2019 8:51 am
Or it's the usual - bent hanger.
Posted : 07/10/2019 9:08 am
