Race Face Evolve XC
[Closed] Race Face Evolve XC
4 Users
I have this chain set on my Orange 5, and noticed a "pinking" last night in my cranks when I stood out of my saddle and pushed hard on the cranks. Is this the first sign that my bottom bracket is on its way out ? Shame, cos I haven't done that many miles on it as yet....
If so, can I use the same removal tool I use for my XT HT II Cranks and any suggestions as to which BB I should use next time ???
Posted : 14/04/2010 7:47 am
Chainring bolts loose?
Posted : 14/04/2010 7:49 am
Dunno - I'll check - good shout though 🙄
Posted : 14/04/2010 7:52 am
Finally! Someone else with the same problem!
I've tried everything on mine, BB, bolts, pedals all to no avail.
I've deveided that it's the bonded join between the non-driveside crank arm and axle, as it only happens at teh left side when loading and unloading the cranks.
No idea of a cure though, sorry...
Posted : 14/04/2010 8:31 am
i had a similar noise - turned out to be the cables tapping together when i pedalled because of the slight suspension bob.
Posted : 14/04/2010 8:38 am
Keithb - I am gonna check everything over tonight - if there is an inherent problem then maybe Race Face are aware.........???
Posted : 14/04/2010 8:56 am
Sometimes the cable ferrule on the end of my front mech catches on the crank arm then 'pings' against the frame
Posted : 14/04/2010 3:34 pm
