What happens to the Propedal when you Push an RP23?
Does it become redundant?
Anyone?
yes
No
Ring TFT, they'll explain
They can do what you like with it.Increase or decrease the choice is yours/theres
I had a feeling that you loose the pro pedal if you get it PUSHED.
Pro pedal is the best feature in my opinion though,mine stays on all the time.
Push leaves the basic function of propedal untouched and improves the overall damping characteristics of the shock. You'll still get the same levels control on each of the PP settings, i.e, slightly compression damped, more compression damped and alot compression damped, but the quality of the damping in the settings will be improved - better transition from platform to movement, better small bump sensitivity, less squatting into the travel, more composed on square edged hits etc...
TBH, After I'd had my RP3 pushed, I barely used the pro-pedal settings again anyway.
For budget reasons I'm now running an old pushed VanR and I don't miss the Propedal.
Next time I'll just get a conventional float and get it pushed.
No it doesn't
