New front wheel XC7...
[Closed] New front wheel XC717 on Hope Pro2?
10 Users
Going on a hardtail, mostly be XC type stuff with a couple of Lakes trips each year, nothing too hairy.
Do I need to look any further than XC717 and Pro2 for £101 handbuilt? Havent had Hope hubs before but know a lot of you like them. Ta.
Posted : 10/04/2010 3:21 pm
Sounds perfect for what you'll be using it for.
May not be an issue, but you may struggle to get fatter tyres, say >2.3, on an XC717.
Posted : 10/04/2010 4:01 pm
2.25 Schwalbe feel plenty big for me. Light is good too.
Posted : 10/04/2010 5:13 pm
Stans ZTR355 is worth looking at
Lighter than the 717 & wider
Posted : 10/04/2010 5:19 pm
 hora
Lakes? I'd do say no. Go for a slightly wider rim- the tiny bit extra gram-weight wont hurt you too much but it will mean you can run your psi slightly lower and not pinchflat soo much.
Mavic 321's here- No pinchflats front or back in almost a year. Ive seen alot of people on rides with me suffer them. Whereas on 4.1/717's I had my fair share.
+1 for wider rims. I'm an aggressive XC rider most of the time, and I've ding'ed and buckled 3 717 rims... and IMO wide tyres don't sit as well on them.
Posted : 10/04/2010 6:14 pm
 hora
Ps. I run my tubes at 30-35psi max and I weigh 220lb BTW. They might not look like much difference but its huge out on the trails.
Posted : 10/04/2010 6:34 pm
Another of my shameless plugs, I've got an XC717 non-disc on a Hope XC hub that I need to get rid of. £40 posted if you're interested.
Posted : 10/04/2010 6:36 pm
OK thanks, will have a look at the Stans rim.
Also, tell me about Pro3 hubs. I had a look at the Hope website, implies they are non-disc only, didnt think that was the case. Are they a worthwhile upgrade from the Pro2?
Posted : 10/04/2010 6:45 pm
If you decide to go for Stans
Give Roger a call - there's no one who knows more about wheels than he does
http://www.wheelpro.co.uk/
Posted : 10/04/2010 7:02 pm
uplink thanks, I will and I will. According to Roger's page the Pro2 is easy to switch from QR to 15mm.....I have 1 of each on my bikes so this makes perfect sense. New Crest rim replacing the 355 might be worth hanging on for.
I know you guys know all this stuff already.
Posted : 10/04/2010 7:13 pm
uplink "Stans ZTR355 is worth looking at
Lighter than the 717 & wider" where did you get you weights from? 395g for 717 and 470g for flow! off their websites.
Posted : 10/04/2010 7:19 pm
What are you on about? The Flow and the 355 are totally different rims. The 355s are lighter than the XC717, <370g IIRC!
I'd definitely get a Hope Hoop on a 355 rim, excellent value, light, easy to convert to tubeless.
Posted : 10/04/2010 7:23 pm
 mboy
And cheaper than the £101 quoted above if bought online from many of the major web based bicylce retailers!
717 is a bit narrow, and a bit flimsy for most uses. Fine for pure XC riding, but even then, you can get lighter and wider rims these days. Stans 355 (or it's new replacement the Crest) gets my vote, though if you want to go wider, there's always Mavic's own 719 (a good rim) or the Stans Flow you could choose without too much weight penalty. Rims like the Mavic 321 provide too much of a weight penalty IMO unless most of your riding is gravity based.
Posted : 10/04/2010 7:28 pm
I think it's called a 355 for a reason 😉
Posted : 10/04/2010 7:31 pm
mboy - 355s on Pro 2 for less than £101 per wheel - any particular places in mind?
Posted : 10/04/2010 7:54 pm
Last thing.....I'm 6'3, weigh 87kg in my socks. Want to shave as much weight off the bike as I can but am I too big for 355/Crest, should look at the Flow instead?
Posted : 10/04/2010 7:56 pm
I don't think you'll get a rear for that price but fronts are ~£95 from most places last time I looked
Posted : 10/04/2010 7:58 pm
sorry clicked on the wrong rim, I go back to watching harry potter. ...... 😀
go for stans they are good!
Posted : 10/04/2010 8:26 pm
Sounds like 355 are getting out of stock everywhere pending the Crest taking it's place. Might have to hang on until May for the Crest to appear.
Posted : 12/04/2010 1:23 pm
