Basically an oil change. How much to put in to each leg and what weight?
Also is there the risk of the rebound damper rod separating from the top bolt? I had this problem whilst servicing some 05 Z1 FRs and no matter what could I get the damper rod assembly to stay connected 😕
Posted : 12/04/2010 8:58 pm
pretty sure most marz forks use 7.5wt. what year are the forks?
Posted : 12/04/2010 8:59 pm
2005's (running them at 150mm)
Posted : 12/04/2010 9:00 pm
[url= http://www.marzocchi.com/admin/download.asp?LN=UK&idC=1592&Campo=ManualeInglese&IDFolder=126&IDOggetto=8369 ]http://www.marzocchi.com/admin/download.asp?LN=UK&idC=1592&Campo=ManualeInglese&IDFolder=126&IDOggetto=8369[/url]
Posted : 12/04/2010 9:07 pm
just the trick 😀
Posted : 12/04/2010 9:15 pm
Thanks guys 😀
Posted : 13/04/2010 6:58 am
