maxle lite - how ti...
[Closed] maxle lite - how tight do you have the QR ?
4 Users
I find that with the 2.5mm grub screw adjustment, at one position it is slightly lighter than I would have a normal QR - still make a hand imprint though. Next click on the screw and it's way tighter than I would have a QR, need significant hand force to close, and particularly to open. I am thinkingh the ligher setting ??
Posted : 19/08/2013 9:13 am
Tighter one. Maxle doesn't work like a traditional QR, but rather expands in the hole on the lever side locking it in place.
Posted : 19/08/2013 9:41 am
ah, thanks for that, it's waaay tight, and I was worried that I might overstrain it in that setting..
Posted : 19/08/2013 10:34 am
I'd have the lighter one personally, the clamping force isn't holding the wheel in. As long as it's fully screwed in prior to clamping, and there's no slack in the lever when it's done up.
Posted : 19/08/2013 10:50 am
Tight enough so that the end of the 9mm rod shears off. This allows me to try and fudge a replacement with a rear hope qr skewer before giving up and buying a replacement maxle.
Posted : 19/08/2013 10:58 am
good ole stw !
Posted : 19/08/2013 10:59 am
The clamping force is just bracing it so it doesn't unscrew itself while riding. Really isn't as critical as it is with normal QR imo.
Posted : 19/08/2013 11:03 am
Toasty - thanks, that is exactly the clarification that I need, cheers
Posted : 19/08/2013 12:17 pm
