Magura Wotan DIY Se...
[Closed] Magura Wotan DIY Service and heat lock-out
Read an old post by member 'auricgoldfinger' that there is a PDF out there on t'internet saying how to do this - any clues?
The problem - having moved to Spain, where it's hot hot hot my Wotans have started to go sticky and finally lock-out completely in the heat. Anyone else had the same problems?
Ta, J
Posted : 19/08/2009 10:22 am
Strange. I read posts when I had my Wotans that they lock-up in the extreme cold.
Wonder if they are very oil weight sensitive because the guys with the cold weather problem used thinner oil and they were a lot better maybe you should try heavier oil when you do yours.
I just found this in a quick search on the Magura site.
Posted : 19/08/2009 10:39 am
