Hi
Does anyone have experience to share of riding this??
Thanks
Paul
Yes... well, when I say riding, I mean pushing and carrying through the boggy wet marsh that seemed to make up a large amount of the route across the top when I did it a few years ago!
Also, the descent down into Ribblehead had been 'improved' and is a set of rocky steps...
Yes, did it earlier this year. Rode it from Ribblehead to Dent - I don't recall it being too bad (i.e. not too boggy or unrideable) and enjoyed the ride.
At first it's firm stone with grass growing through to the gate after 200m, then it's steep gravel to the radio mast (tiring), after that it's heavily rutted and strewn with rocks and boggy bits for maybe 200m before you reach the sanitised bit (orange gravel). This gives way to bouldery rock with boggy bits when wet till you reach the next gate when it becomes grass all the way to just before the summit, where it's sanitised gravel again. The downhill is gravel with lurking channels cut by rainwater till you reach a cobbled stairway to a gate. Then it's paved with lumpy rock for 100m, then gravel over rail crossing followed by 2 rocky fords. If you go SO at railway underpass it leads to a shallow cobbled staircase down to the viaduct
by radio mast:
[url= http://www.bogtrotters.org/rides/2008/10aug/280p.jp g" target="_blank">http://www.bogtrotters.org/rides/2008/10aug/280p.jp g"/> [/img][/url]
typical:
[url= http://www.bogtrotters.org/rides/2008/10aug/_DSC0283.jp g" target="_blank">http://www.bogtrotters.org/rides/2008/10aug/_DSC0283.jp g"/> [/img][/url]
downill:
[url= http://www.bogtrotters.org/rides/2008/10aug/_DSC0316.jp g" target="_blank">http://www.bogtrotters.org/rides/2008/10aug/_DSC0316.jp g"/> [/img][/url]
(the walled bit is where it crosses railway)
Simon offers a much better description - I just remember when I have cr@p rides so I don't ride the same route again for a while. This wasn't one of them.
Basically, what Simon says. I rode it about 2 weeks ago and the going was good. Some photos here
[url= http://www.flickr.com/photos/pennine/sets/72157621863406785/detail/ ]Craven Wold[/url]
Domino: Did you do Buckden Pike?
Not yet Pennine, saving it for when I am back from my hols so likely to do it in September.
I'm guessing I must have done it on a bad day... as I don't remember much else apart from the bog and the steps!
the section above the mast used to much boggier, but a lot of it was sanitised, though not all the way down for some reason...
[edit] or perhaps they did and it was promptly washed away!
Must admit I pushed a bit on that rocky section Si 😳
Aaaah, that might be why, thinking about it I don't remember there being any trail sanitisation after the mast until the rock steps on the other side.
Hi
Many thanks to all esp. sfb, for the feedback. Have a long weekend near Ingleton and may partake.
Paul
