Got an again Lyrik coil u-turn with Mission Control. It was serviced (under warranty for cracked lowers) at the end of summer last year. The lockout was working fine after this.
Over the snow-season, the bike was in storage, stood up on the back wheel. When I got it out in spring, the lockout wasn't working. Figured it would come back once the oil got circulating again, but no joy. Have changed the oil since then as well and still not working.
Any ideas?
Bump?
Is the fork working ok apart from that? I had the fork lockout on my coil U-Turn Pikes stop working but it was combined with them only getting about halfway down the travel, so it doesn't sound like what's up with yours if that's the only issue.
Did you let Hora touch them?
The floodgate is the centre disc on this photo: -
You can see how the floodgate works here: -
It may be that the centre disc has popped off (This is the floodgate mod many people do to improve oil flow through the Compression circuit).
Try adjusting the floodgate setting to see if that makes any difference.
Other than that it may be something like a failed seal which sits under the centre disc on pic 1.
