Lumicycle Halogen t...
[Closed] Lumicycle Halogen to LED conversion with piccies and a step by step guide.
nice 😉
Fd
Posted : 06/12/2009 1:11 am
Posted : 06/12/2009 1:14 am
looks good PS
that switch will work with the Bflex but for the ebay drivers it will have to be a lockable switch, not a momentary one.
I've just ordered some of that heatshrink, it does look much better than insulation tape.
the difference between the HID and your conversion is massive 😆
Are the XPG specif optics the same size as the cutters?
Posted : 06/12/2009 9:25 am
Externally the XPG opitics are exactly the same as the XPE.
Link to XPG Cute 3 datasheet:
[url= http://www.ledil.com/datasheets/DataSheet_Cute-3-XP-G.pdf ]http://www.ledil.com/datasheets/DataSheet_Cute-3-XP-G.pdf[/url]
Link to XPE Cute 3 datasheet:
[url= http://www.ledil.com/datasheets/DataSheet_Cute-3-XP.pdf ]http://www.ledil.com/datasheets/DataSheet_Cute-3-XP.pdf[/url]
I originally wanted a narrow spot but as Trout mentioned above the XPG adds 8deg to the XPE optic, which has actually worked out really well, so the XPE optic is fine.
Posted : 06/12/2009 10:23 am
Simple retrofit when the new optics become available 😉
Fd
Posted : 06/12/2009 2:23 pm
Finished doing mine today with the XPG's and the other parts recommended by Chucky. Took about 1 1/2 hrs, most of which was spent trying to get the parts into the can. Apart from getting heatsink paste EVERYWHERE I had no problems at all. Am yet to give it an off-road test but the light seems way brighter than my 20W halogen. Many Thanks for the easy to follow guidelines!
Posted : 07/12/2009 8:52 pm
My pleasure.
The cutter stuff has just arrived for you guys waiting.
I have not opened up the package yet, but it looks like we got away with no VAT or Import tax 😀
I'll try and get the stuff sorted in the next few days and posted out at the weekend at the latest.
Will also do my Lumi HID conversion with photo's and a detailed how to as well, for those of you who asked for it.
cheers
Chuck
Posted : 07/12/2009 9:09 pm
Cool nice work sir - that's the best news in ages.
Posted : 07/12/2009 9:15 pm
I guess these XPGs are all cool white? Be interested to know how you folks get on with them from a perceived contrast point of view.
Posted : 07/12/2009 9:39 pm
i'm confused, never having anything to do with elec-tricks before, but i'm also intrigued AND i have a housemate with a soldering iron.
i've two lumi halogen cans and a 14.4v (i think) endurance battery (the biggest one lumi offered at the time of buying (~2 years ago)).
the DRIVER does what exactly? controls the amount of power reaching the LEDs so that they don't blow? does it have to be the same one that Chucky listed easrly on? will [url= http://stores.shop.ebay.de/PCB-Components__W0QQ_armrsZ1 ]700mA, 1000mA or 1400mA (click here)[/url] be ok?
judging by some of the pics (sequence of three on the first page) these things are silly bright. i find 35w/38 deg halogen is enough for most riding.
warm white, cold white, XRE, XPG. what should one order? also, narrow or medium angle lens? is the narrow enough when using the XPG bulbs?
many thanks
J
Posted : 07/12/2009 9:43 pm
You guys all have mail reference me posting the stuff out. (after you have paid of course) 😆
Alpin, your battery is probably a 14.8volt one.
The drivers you have linked to as far as I can see are for up to 6volt.
The ones I used are for up to 24volt.
I have not tried an XPG yet, but looking at the ones that have come with this order from cutter, my view would be a triple XPG R4 with a narrow optic.
The mediums are a bit too wide for me.
This would give in the order of about 700 plus lumens (if not a bit more)
Posted : 08/12/2009 10:45 pm
Chucky
The R4 has a nominal output of 130 lm, driven at 1000mA it's 2.5 times that, giving 325 lm.
x3 should give 975 lm. (an XPG R5 would be 1042 lm)
These are datasheet numbers so are to some degree theoretical, I'm not sure how to calculate/measure losses in the system to get the real figure though.
Posted : 09/12/2009 10:36 am
Only taking into account the lumen measurement of a light is like only taking into account the BHP figure of a car. A datasheet lumen measure will only tell you the theoretical total maximum light output [i]according to the manufacturers of the LED units[/i].
Much more important, IMHO, is the colour temperature and beam pattern, the latter determining the illuminance (Lux) figure, or the amount of light per square metre. Beam pattern preferences will also vary from rider to rider, and I reckon flexibility is the key.
Posted : 09/12/2009 12:37 pm
Great Thread.
All 3 factors have importance. But, so long as I've a fair few lumens, then I can suffer a warmer than prefect colour temp and less than optimal beam pattern. ( I prefer cool light, flood on the bars, spot on the helmet )
We're compromised by having to source off the shelf parts.
I like this conversion and I'm looking forward to seeing more beam shots, before/after and end result pictures of the build people will be doing.
L.
Posted : 09/12/2009 12:57 pm
The spectral intensity of sunlight peaks at about 600nm wavelength with a smooth curve at either end(visbile light being around 400nm to 700nm ish). The ideal output for a bike light would be a similar profile giving 'daylight' feel to it. Unfortunenately I don't think that's possible with LEDs.
The XPG has a significant spike at about 450nm, the blue end of the spectrum, and relatively little at the 600nm end. This is why they have a bluey, ice white kind of colour. In my experience can this can lead to contrast issues, particularly with a helmet light on its own.
Has anyone tried a multi LED setup with differing BIN lamps to try and construct a sunlight like spectrum? Maybe that should be the next project 😕
Posted : 09/12/2009 1:33 pm
bloody hell lad's, this is getting a bit techy.
Posted : 09/12/2009 1:49 pm
It's amazing how Wikipedia can make an expert out of anyone! 😉
Posted : 09/12/2009 2:02 pm
I'd be happier if you could get LED's that match the 'look' of the light from the halogen lumi's. I find the warmer light helps make out details and stuff. Can't really describe why.
That is my only concern about doing the conversion.
Was totting up the cost of it all last night and it's looking like £40 or so with the heatsinks & stuff.
Will get round to ordering it at some point. Need to get a soldering iron as well from somewhere. The other half is excellent at soldering so no worries there.
The ebay bloke doesn't have any of the drivers at the moment; he has the screw fitting one (rather than solder) but presumably that's loads bigger.
Posted : 09/12/2009 2:12 pm
Cutter do a multi colour temp triple board (with three different tint LEDs on the same board)
Its all to do with colour rendering, depth perception of colour temperature & contrast ratios.
Not to mention that natural light comes from above & bike lights from your bike (so the angle of reflection becomes an issue)
Posted : 09/12/2009 2:19 pm
Yeah, sunlight is very 'orange', though nothing like as orange as tungsten filament lighting (old school incandescent lightbulbs).
At low light levels, the rods in our retinas are much more sensitive than the cones (the 'colour receptors'). The peak of the rod response is around 500nm, a blue-ish-green colour, which unfortunately is something of a gap in the available spectrum of both 'white' LEDs of all colour temperatures and monochromatic colour LEDs. At least one light design on Instructables advocates using cyan or green LEDs close to the peak rod response in order to get the best visual response for the actual light output. Researching this a bit further, I found that many people who tried this simply found that it made everything look a bit too weird to be usable.
Interesting thread on colour rendition [url= http://forums.mtbr.com/showthread.php?t=485410 ]here[/url] including using two different Cree MCE colour bin LED types to get a better compromise of overall light colour. Also, comments from one guy who said he used a red LED for jogging and didn't notice the colour after a few minutes until he got back into the vicinity of white-ish light.
Posted : 09/12/2009 2:47 pm
It's pretty simple really - sight has evolved with sunlight, so our eyesight is best suited to wavelengths in that spectrum (orangey/yellow).
Posted : 09/12/2009 2:52 pm
Amber LED lights, anyone?
Posted : 09/12/2009 3:02 pm
All very interesting . . . just back from a 2 hour run round the local hills with an XP-G triple bar lamp and an XP-G triple helmet lamp, the bar one is the Lumi HID conversion I did and the helmet one is a standard lumi halogen case running with the eBay 970mA regulator with my own 7mm thick slug behind the LED's . . . a very tight fit which I wasn't sure I could get it to work . . . but it does, just . . .
So long as you keep moving the small case temp is fine, but if you stop for any length of time you need to switch off, it only takes a few minutes for the temp to start rising rapidly . . . but I can live with that . . . this is with an ambient of only a few C . . .
One thing that is noticable is that the helmet lamp appears brighter, when in reality it isn't . . . I guess it being more or less co-axial with your eyes makes for better reflection . . .
Anyway . . . on the colour balance side of things, I don't notice them as being markedly blue (when riding) at all . . . I also had a 20W lumi halogen to make some comparisons and it looks terrible, dull, and nothing like as good (and twice the power consumption) . . . the LED output is very nice, makes a HID look very monochromatic . . .
Anyways, on the way back down the hill I have to use about 600M of more or less single track public road, unlit (middle of nowhere), between trails . . . I had both lights on full bung, and encountered two cars, both pulled into passing places and stopped as I passed 😉 . . . I guess they can't work out the two vertically placed, very bright, lights are so stop (sensible drivers around here) . . . 😉
Posted : 09/12/2009 9:26 pm
Sounds spot on FD.
just printing postage labels etc ready for posting all this order.
Hopefully people will post on here to say how they have gone on with their conversions.
about to swap my XRE for the triple XPG's.
300-400 lumens extra for no extra drain, just what the doctor ordered.
ironically some of the guys we ride with think that a car is behind us on the unlit roads when me and a mate are riding alongside each other. 😆
Posted : 09/12/2009 9:36 pm
Chucky
when I am just behind you with my lights I just thank god we ban Lycra on our outtings!!!! :mrgreen:
Posted : 09/12/2009 9:45 pm
Nige, When you are behind me with your twin set-up I can see bugger all!! Even with 1000lumens
and for that i'm wearing Lycra next week 😈
Posted : 09/12/2009 9:54 pm
fergusd - some questions:
How did you establish you need to turn it off?
Does your driver have a thermal overload? and is it being tripped?
Have you got any external heatsinking?
I'm using the bFlex driver with 5 power levels and I was planning on dipping it to lowest level when I stop, so I don't blind people for one thing and to control the temp. Hadn't planned on having to turn it off though.
Posted : 09/12/2009 10:41 pm
Burned fingers after 10 minutes spent watching a herd of deer.
No I'm using the 5 quid ebay job rather than the 20 quid bFlex, secondly I have no use for bFlex functionality in a helmet lamp and lastly given the heatsink slug I am using there is no room for a bFlex. A bFlex in this case is a waste of money.
Yes but not fitted 😉 . . . My ideal objective is a lightweight helmet lamp, any mass reduction is welcome and I thought I'd see just how usable a non heatsinked version was . . .
If you reduce current to 500mA with the XP-G the heat output is negligible . . . so cutting to 1/2 power means you have no heat issue . . . I'm runing things at 1000mA (max drive current) where heat is much more of a problem . . .
Posted : 09/12/2009 11:08 pm
Thanks fergus
Maiden voyage with mine tomorrow night. Max setting is 1000mA but I do have an external heatsink. Plan was to run the majority of the time at less than full power and only crank it up when I really need it.
Posted : 09/12/2009 11:15 pm
Have a good one, you'll be fine on max all the time in this weather . . . enjoy 😉
Posted : 09/12/2009 11:18 pm
@Chucky
If you somehow end up with enough spare bits for a Lumi can conversion, let me know, I'd be interested. Can source a driver myself, really just LEDs and optics I need, but a spare driver wouldn't go amiss.
Ta.
Posted : 10/12/2009 12:43 am
You might be lucky Dr, i'll let you know in a few days.
It will only be the LED and optic though.
Posted : 10/12/2009 8:48 am
No problem @Chucky, that should be enough to tinker with when I get round to it. Let me know what you got and how much, email in profile.
Posted : 10/12/2009 10:57 am
Have been running my Lumi can as per Chucky's build but with XPG's for a couple of days now. On my 45 minute commute the can hardly gets warm, which I've found a little strange. I'm hoping it's not getting ed hot inside!!! (It used to get very hot with my 20W halogen). The light is more 'white' than the halogen but brighter IMO.
Posted : 10/12/2009 2:25 pm
If you are only driving them at 650mA then they won't produce that much heat . . .
Regardless . . . your halogen bulb was about 2-3% efficient so produced about 17 watts of heat . . . your LED setup is probably ITRO 20% efficient and in your case probably only produces ~5 watts of heat . . .
Posted : 10/12/2009 3:56 pm
Sorry to be very lazy and not reading this lot, but I have the old 13.2V Halogen lumi set sitting doing nothing. Is this convertable?
Posted : 10/12/2009 4:08 pm
@oldgit - Yes!
Posted : 10/12/2009 5:39 pm
There is currently a shortage of drivers, has anybody tried to squeeze in the 650mA version with screw terminals??
Posted : 10/12/2009 7:58 pm
I was thinking the same, So I bought one and then I was going to De-solder the connector. The MINUTE I paid for it and I get an email from the seller saying that the solder connection drivers are due in at the end of next week.
Typical. 🙁
*Update* the seller has agreed for me to swap a connector type for the solder type when they arrive. What a gentleman. 😀
Posted : 11/12/2009 12:06 am
The guy selling the drivers on eBay seems like a sound chap. I contacted him regarding the inner workings of the dimming / shutdown pin and he put he straight on to the data sheet of the main chip used in the circuit. I could now bypass him completely and reverse engineer his board, but at that price, there's not much point.
Posted : 11/12/2009 3:30 am
We all have troutie to thank, he pointed me in the ebay guy's direction.
and just to add the ebay guy is 'spot on', honest and very well priced.
I bet he wonders what the hell has happend in the last 4 weeks 😆
He never had quite the same demand before we got the Lumi casing thing to work.
Just as an aside, you guys have had more running time with these lights than me. I've hardly been out these past 4 weeks due to work. 🙁
The idea behind it was just to make a commuting light. The halogen case was used because Lumi do a glowring for it, which I thought was a great idea for commuting.
But now, thinking about it, with a smallish Lithion battery (circa 2.2amphr) it will probably make a great helmet light given it's low weight.
Piccies and more opinions when these are all built please.
Happy soldering.
Posted : 11/12/2009 8:43 am
The maiden voyage with mine went swimmingly last night. Very pleased with the amount of light and the beam pattern from the Cutter Cute 3 optic.
Had it running at full tilt (1000mA) for most of the ride and it hardly got warm at all (it was -2deg though).
I'm considering converting my other Lumi can in the same way but with the quad board instead.
Should also be picking up the CNCd housing for a x7 XPG bar light today.
I'm getting rather carried away with this home building malarcky. 😀
Posted : 11/12/2009 8:46 am
Chucky - that's exactly the setup I used last night (see pics in earlier post). I'm using the 2.2Ahr Li-ion battery from my original Hope HID fastened to the shoulder strap of my camelbac. Very neat and much lighter than the Hope head unit.
I haven't run the battery flat yet but sensible use of the lower power levels should eek it out over 3 hrs.
Posted : 11/12/2009 8:51 am
Just completed the conversion on junkyards Nightpro headlight.
I must admit it was easier than the lumi one due to a little bit more room. The light is very neat and the switch integral. Used the switch as an off and on rather than a 1/2 power. The switch housing retaining screw even locates into the heatsink ensuring an good contact with the casing.
a couple of piccies of it here.
Posted : 13/12/2009 8:37 pm
Hi i have 2 of them ebay 970ma drivers that i no longer need if anyone wants one £6.50 each posted email in profile cheers.
Posted : 15/12/2009 6:42 pm
Anyone tried a conversion on one of [url= http://cgi.ebay.co.uk/CNC-Alloy-Halogen-Bicycle-Light-Lamp-Lumicycle-Compat_W0QQitemZ250538099651QQcmdZViewItemQQptZUK_SportsLeisure_Cycling_Bike_Lights?hash=item3a553c03c3 ]these[/url]? With nearly three inches front-to-back there should be loads of room for more LEDs, a good heatsink and a driver board.
Posted : 16/12/2009 10:57 am
I think you should be able to get the cutter LED's on a MR16 board (50mm) as opposed the 35mm MR11's ones used in this thread. If you can it should be spot on with a suitable heatsink.
I don't have any LED's left BTW Doctor, sorry
Posted : 16/12/2009 1:41 pm
Damn it. Tried the conversion and followed instructions, but it wouldn't work when finished. Can't see why, checked all the soldering as i check the LEDs the damn track peeled off the board.... yay i get to fork out for another LEd board and wait for it to arrive.
Plus i get to convert it back to standard so i can use it tomorrow.
I'm not happy!
Posted : 16/12/2009 2:16 pm
sorry to hear that wishiwascalledsteve, if you get stuck again mail me.
Posted : 16/12/2009 3:13 pm
Dave received the stuff yesterday...BIG thx for organising it etc!! Just waiting for the Ebay drivers now, went for the 970mA ones 🙂
DrRad, I think those kits are from OldGit off here??
Posted : 16/12/2009 4:05 pm
 mjb
I was just wondering if people were managing to disassemble the lights OK, say to upgrade the LEDs or driver board?
The heatsinks i've made are quite a good fit and i'm not sure how easy they'll come out once all the wires are in place and the heat transfer paste has been added.
Posted : 16/12/2009 7:13 pm
@Chucky - doesn't look like Cutter do 50mm optics, looking elsewhere. Thanks for letting me know about the LEDs, will possibly head up another group buy if I end up doing a Cutter order.
Posted : 16/12/2009 9:47 pm
mjb - I've seen the heatsinks tapped, so that you screw two screws in to aid extraction. Look at [url= http://www.elisanet.fi/kai_js_nurminen/ ]this guys site[/url] under DIY lights
Posted : 16/12/2009 9:57 pm
I hope the Mods don't mind me posting on here - I'm 'The eBay guy' who sells the LED drivers. I was pointed to this thread and thought I could offer some useful comments for anyone who is going to try this.
The new batch of PCBs is due tomorrow so unless I've made a horlicks of the layout I should have more drivers built up ready for the weekend.
I've noticed a few people are using the half-power mode. If there is interest, I can configure the drivers so you get half-power simply by connecting the 'A' and 'IN-' terminals via a switch - you couldn't get the shutdown function this way though.
Also, people are talking about thermal issues. It should be possible to add a large thermistor between the 'A' and 'IN-' terminals to reduce the current as the temperature increases. The only down-side of this is that you will no longer be able to get 100% output current. I would suggest something like a 1M NTC thermistor with something like a 470k fixed resistor in series. Using something like order code 61-0458 from Rapid Electronics, this has a resistance of 2190k at 10C, 1000k at 25C, 309k at 50C and 133k at 70C. The formula R / ( R + 200k ) gives the fraction of full scale output current for my drivers so at 10C you would get ( 2190 + 470 ) / ( 2190 + 470 + 200 ) = about 93%. At 25C you'd get about 88%, at 50C about 80% and about 75% at 70C. Decreasing the value of the fixed resistor would reduce these percentages if this doesn't keep the temperature low enough.
The net result of this mod. should be that you get nearly full output when moving and the air flow is keeping the light cool (i.e. when you need it most) but when you stop the thermistor will react to the temperature rise and reduce the current to limit the temperature. Light output will drop when this happens but that shouldn't be a major problem when you are stopped.
You should be able to still use the half-power mode by running the 200k resistor in parallel with this circuit. You'll actually get slightly less than 50% as at 25C the thermistor circuit will reduce the 'effective' resistance to 176k but I doubt you'll notice the difference. You will lose most of the thermistor-induced current reduction when in half-power mode but that shouldn't be a problem as you are running at a much lower current anyway.
I'm looking at ways to mount both driver and LEDs on the same circuit board but unfortunately my PCB fab can't do thermally enhanced boards so I need to look at alternatives.
I'm also looking at different driver ICs including one which takes a lower input voltage than the Vf of the LED string and one which has a higher output current limit. These aren't imminent though, especially the latter as this requires me to work out how to solder a tiny chip by hand... Also, I am doing a version of my standard driver that has a PIC microcontroller on-board which will allow better temperature compensation and push-button control of the light level.
If anyone has any questions I'll happily do my best to answer them provided by doing so I'm not breaking forum rules.
Posted : 17/12/2009 12:27 am
Welcome to the world of STW.
Nice to see somebody spending time to see what we would like to have on future drivers.
slightly smaller would help if possible. especially for these Lumi halogen installations.
Nice product by the way and very well priced.
keep up the good work.
Posted : 17/12/2009 9:37 am
The new version of the drivers is slightly smaller, but only by about 1mm all around. A quick warning that the order of the terminals has changed! It is difficult to decide the optimum size as the components of the driver also generate heat so I decided to go for a larger board the aid dissipation (the original version was a fair bit smaller but was originally only designed for 1W LEDs). I could go smaller for 3W LEDs but not really for 5W ones unless you want to worry about cooling the driver as well!
I may have the opportunity to get some more PCBs made in January. Would there be any interest in a version of this driver with the components on-board for the thermistor and half-power mode? All that would be needed external to the driver would be the thermistor itself and the power switch. This would be a cheaper solution than the version with the microcontroller on-board but with less functionality.
Any other requests? As long as I can sell enough to cover my costs I will consider doing 'specials'.
Posted : 17/12/2009 10:36 am
Excellent, BlackCatTech thanks for jumping on board.
I was looking at your e-bay items the other day & saw you had no solder-on drivers in stock. I'll be keeping my eye out & placing an order once they are back on.
Need to really pull finger out and get it all ordered. I made a list and everything, but have yet to make a purchase. Should really get the Cutter order underway, as that'll probably be the longest lead time.
Posted : 17/12/2009 10:39 am
Lot of functions on boards are nice but I generally only use the Duo mode (Hi/Lo) & the over temperature protection on the bflex so a driver with those (on board thermistor sounds good) would be great.
Also the option to buy with 4 inches of wire already soldered to each of the driver terminals would be useful.
Posted : 17/12/2009 10:44 am
 mjb
nockmeister - Member
mjb - I've seen the heatsinks tapped, so that you screw two screws in to aid extraction. Look at this guys site under DIY lights
I did think about that but assumed that the LED board would cover most of the heatsink and so they'd be no space left (i'm still waiting for the bits from cutter to arrive to check this).
Posted : 17/12/2009 11:36 am
Boards are here, I've built and tested one and all looks good.
For added stylishness (not that you'll see them inside a light fitting...) they are now Black.
I'm waiting for a few components due today before I can build a large batch but should be able to list on eBay tonight or Friday.
I should warn people that prices may have to go up in the New Year - my costs have been rising for a while and I've tried to absorb them but with the VAT going back up I may not have any option.
I'll look at the board changes mentioned but as I'm having to piggy-back these on another PCB order this is unlikely to be ready before the end of January. Is the shutdown function still desirable, or are people happy to use a main power switch? I ask as every terminal I need to add will increase the PCB size so if shutdown isn't needed I can probably save a bit of space.
Posted : 17/12/2009 12:37 pm
Are the 3W boards avalable in 970ma? I've fitted the 650ma one and there are no heat problems so I'm thinking of changing it to a higher output to get more lumens. A 970ma board with a built in resistor to reduce the output to 50% would be ideal...
Posted : 17/12/2009 12:52 pm
from my point of view the shut down requirement is lower priority than the 1/2 power and temp.
To have a driver with those two additional features would be great.
Posted : 17/12/2009 1:01 pm
Squeakybrakes: The board is generic to 1W, 3W and 5W versions. The 3W and 5W also share all but two components. The power ratings are a bit misleading - no two LED manufacturers seem able to agree on ratings. The current rating is the most reliable figure to use as LEDs are current-mode devices. As standard the units are available as 330mA, 670mA and 970mA. I can do pretty much any variation under 1A as a special as long as I have the appropriate resistors to set the current.
Is it worth listing versions with a half / full power mode instead of a shutdown function? Cost would be the same, it's just a case of changing one resistor on the board.
Posted : 17/12/2009 1:08 pm
Does that mean that the 970ma can be used to drive the cutter board with 3 x 1W LEDs? The 1/2 power option would also be my preference.
Posted : 17/12/2009 1:26 pm
Brilliant stuff...BlackCatTech,any chance of getting my 2boards modded for full/half power(it's Ian BTW)?? Yes deffo worth advertising with the functions you have mentioned rather than shutdown.
mjb - well if you only use thermal compound rather than thermal adhesive you would just need to remove the pcb to get access to the extraction threads. I'm not sure but it might just be as simple as drilling through the pcb???
Posted : 17/12/2009 1:45 pm
Seconded request for the boards to be available with wires already attached as this would allow easy lash-ups... errr... I mean [i]prototyping[/i] with screw terminal blocks.
Posted : 17/12/2009 2:02 pm
Ian: No problem, should be able to have these ready for tomorrow afternoon if you are about to pick them up.
Squeeky: Can you post the link to the LED board you mean? 1W LEDs are usually 350mA so while you could run three in parallel, that isn't usually recommended for power LEDs.
All: Will look in to options with wires attached. I'm not sure what thicker wire I have - 7/0.2 is rated to 1.4A but it's always better to use more substantial stuff to minimise losses in the wire itself.
I will also do a version with the half-power option. For this you would connect 'A' to 'PWR-' for half-power mode, and leave it unconnected for full power mode. You could add the 1M thermistor between these terminals with the switch shorting it out for half-power mode. You would then get 92.3% power at 10C, 85.9% at 25C, 72.6% at 50C and 63.8% at 70C
Posted : 17/12/2009 2:29 pm
Hi BlackCatTech...yep no problem, I'll bob over at 3pm if ok?
Posted : 17/12/2009 3:42 pm
Just thought I'd mention that the drivers are now available on eBay again. I've listed a version with the half-power dim mode as well as the standard ones. I've not had the chance to look for other colours of wire so I can't offer pre-wired ones yet, probably Monday now.
I also had a good long chat with the Nockmeister today and it sounds like some of the other things I have up my sleeve may be of interest. I'll try and get them complete as soon as possible so keep an eye on my eBay stuff.
Posted : 18/12/2009 9:42 pm
@BlackCatTech - be interested to see what you have up your sleeve, please post here when they're available so we know to look 😉
Posted : 18/12/2009 9:58 pm
Any switch recommendations for Lumi cans to go with the 1/2 power option Black Cat drivers?
I'm presuming that a 3 positon switch will be needed? Looking at Farnell's site it's all a bit overwhelming!
Posted : 18/12/2009 10:37 pm
@zangolin - you could go with the original Lumi switch and just unplug to switch off.
Otherwise, go with type F here:
http://www.maplin.co.uk/Module.aspx?ModuleNo=2341
...and use one of these toggle covers:
http://www.maplin.co.uk/Module.aspx?ModuleNo=2348
...if your original Lumi cover is no more.
Use one half of the switch to switch the power, the other half to switch the dim setting on. I'll try to do a proper wiring diagram if anyone needs one...
Posted : 18/12/2009 11:01 pm
 gray
I thought that too, but found that the fatter base of the DPDT switches like that one don't fit in the Lumi can if you want to use the existing hole.
If using the standard Black Cat driver, then it's easy enough to use a SPDT switch such as the Type B Maplin one to have a configuration such as off-full-half (where the off mode is a soft off, so technically not quite as off as unplugging the power cable, but effectively the same), by using the control terminal and a resistor. The instructions that come with the drivers are excellent.
Posted : 18/12/2009 11:29 pm
People should be aware that with the 'Dim Mode' drivers the off-full-half option is not available. To turn off you need a separate switch in the power rail.
Using a double-pole, centre off switch you can use one pole to switch the power and another to control the dimming. For example, if you have a double pole, centre-off switch you can wire the 'common' on both poles to 0V. Connect *both* sides of one pole together and run these to the 'PWR-' terminal (IN- on older drivers). Then connect one side of the other pole to the 'A' terminal. (Connect via a 200k resistor for standard drivers, direct connection for dim-mode drivers)
You will then have full - off - half. Not ideal as you have to go via 'off' to change mode but still an option.
The Dim-mode drivers have the resistor described in the data sheet built in, the down-side of this is that you can no longer access the control terminal directly so can't put the driver in to shut-down mode. Next time I get some PCBs made I'll do a version that has both half-power and shutdown modes.
If you are looking for switches I find Rapid Electronics are fairly good and cheap - the trouble is that unless you are near Colchester you need to spend £30 to get around the handling charge. The problem there is that they have so much interesting stuff you can easily spend that much on things you don't really need...
Posted : 19/12/2009 12:15 am
Nice One Steven the 2 mode on the drivers is a good upgrade and a lot less faff for the users .
I have used quite a few of your drivers and have to say they have been solid little things .
Be interested to know what else you have in mind
Posted : 19/12/2009 6:52 am
Fantastic thread!! I have often heard people with almost zero electronics knowledge argue in favour of the pricing of high output lights. The component prices are very low in comparison to the shelf price of an engineered system, but the mark up is such, that you have to have deep pockets or be very very enthused to take the plunge.
I have had three lots of halogen lights, my first set was acquired in 1998. I paid £75, but thought that was a bit steep at the time. Since then, firms like Lupine have driven prices into the stratosphere.
Just had a look at one of the beautifilly engineered lamps from my ageing Cateye ABS35 to see if there is enough room to facilitate one of these high power upgrades. I'm out of luck as the driver would never fit, plus the heatsink fins on the inside would make getting a thermal bridge to the body rather troublesome (if not impossible). Shame since I was once trained to MOD standards ans spent 2 years manufacturing electronics assemblys for things like weapon control systems on fighter aircraft.
I thought i'd see how much a set of lumicycle lights are and am shocked to find their halogen set ups are now £60 more than they were when I last looked (£200).
WHY ARE DECENT BIKE LIGHTS SO STUPIDLY EXPENSIVE? 👿
Posted : 19/12/2009 10:05 am
@spongebob
It must be the outlay>units sold I assume. You think in the grand scheme of things it's only us night riders or 24 hour'ists that buy them.
Posted : 19/12/2009 11:38 am
@spongebob
As my mother would say: because they charge what people will pay. Same reason a cup of coffee can set you back £3
Posted : 19/12/2009 1:27 pm
As others have commented part of the cost is simply due to the significant outlay needed to build these things. I'm lucky that I found a good PCB fab that allows me to mix a number of board designs on a single panel as otherwise I probably wouldn't have started doing these drivers. Even then I have to outlay enough to buy components in 100s to keep the cost down so I'm reliant on selling a fair few quickly to pay off the credit card bill.
It is a similar problem for the casings - you need to pay someone to do the tooling or CNC programming and there will probably be several parts required so you could be looking at thousands in set-up costs alone. You'd need to buy a significant quantity to get the unit cost down to a realistic level and unless you can be sure of selling a significant proportion in a short time you run in to cash-flow problems.
I'm certainly interested in looking in to doing a complete system - I can tailor the electronics to suit giving packaging advantages - but until I find a good CNC company with low set-up costs I'm struggling. Of course once you start doing these things commercially you also have a much bigger paper-trail to follow, you have to register under the WEEE directive, have to prove the units meet CE standards etc. If you can be sure of selling things in the millions like radios, DVD players etc you can pretty much ignore these costs but if you are talking thousands then they become more significant I'm afraid...
Posted : 19/12/2009 1:54 pm
A quick overview of other things I'm looking at for Troutie and anyone else interested:
Osram do a version of their 'Dragon' range with lenses built in. I've combined one of these with a Linear LTC3490 on a single board to get a pretty decent commuter / head mounted light powered from 2x AA cells. Only trouble is packaging it to be waterproof. I'm meaning to start selling these for DIYers soon.
I've got a version of the driver board with a PIC built in. I'm planning to have this with either a thermistor for temperature control or with a battery monitoring function that lowers the output when the battery gets low as a 'get you home' function. I'm planning to have the option of either a pot for full-range dimming (not so useful for bike lights I'd suspect) or a push-button to cycle through various power settings.
I also have a circuit that can boost from a single Lithium cell to drive 2x LEDs. Not sure if it will manage 1A or just 700mA - will have to try it out! This is based on the National LM3410 which shut cut-out at around 2.7V which is ideal for protecting lithiums from over discharge.
Future plans including trying to hand solder the Zetex ZXLD132x range and trying out a 0.8mm FR4 PCB with plenty of thermal vias and 3x Cree LEDs plus driver on a single board. Getting heat away from this one may be a challenge but if I can solve it (or find a fab that does thermally enhanced PCBs cheaply) then that will be a great combined solution.
Main trouble is that I've got a reef aquarium system with a touch screen controller to get finished as an urgent priority so these will be a while in coming I fear.
Posted : 19/12/2009 2:04 pm
Page 3 / 5
