Sorry - Kenda Neveg...
[Closed] Sorry - Kenda Nevegals 2.1 DTC - Any good?
10 Users
Good all rounder? Some suggest poor for "aggressive" cornering - how would they compare to MK Protection 2.2's for the summer? Any good on rocks as teh knobbles are long? Draggy on tarmac?
Posted : 13/04/2010 10:56 am
 Earl
I find them a good all rounder front and back though they are draggy both on tarmac and on trail.
Posted : 13/04/2010 11:20 am
Opps - I'll have a look in previous posts for these then (at least 10 😉 ) 🙂 Sorry!!
Edit: Cheers Earl 🙂
2.1's not as good as the 2.3's, I use the 2.3's and have been using them constantly for the last 12 months, all weathers, all surfaces with no issues. Never found them draggy either and run them ghetto'd at 25psi front and 30 rear on an orange 5 (nev on rear, blue groove on front).
Posted : 13/04/2010 11:24 am
As per usual I bought something without investigating it properly - £30 for a pair of tyres!!! Sounds like they will be OK - Maybe I'll use it on the rear and a spare MK on the front for the "dry" summer 😉 Will be on my HT BTW 🙂
Posted : 13/04/2010 11:26 am
The Stick-Es are the most draggy tyres in the history of the world, ever (grippy as hell though). DTC aren't so bad, though I still prefer the Maxxis Advantage over Nevs as all-rounders, similar levels of grip to the DTCs, but roll better (I ran Nev/BG for about three years and switched to Advantages last year). Only problem with the Advantage is the dodgy sidewall. For regular rocky stuff I'd go with something a bit beefier.
Posted : 13/04/2010 11:28 am
Yeh got some Advantages and they are a bit draggy on tarmac but bloomin grippy. Couldn't resist the offer though 🙁
Posted : 13/04/2010 11:30 am
The Nevs are decent quality all-rounders. Not the fastest or grippiest, but can cope with most riding. If they seem too slow you could always chuck something faster on the back. I use Nevs for almost all my non-summer riding.
Posted : 13/04/2010 11:36 am
Funny, I thought they were far less draggy than supertacky High Rollers.
I really like the Nevs, DTC or Stick-E, even though they aren't very fashionable they just seem to be about right for most of my riding.
2.1 Nevegal DTC in use all year round on my Orange 5 at 25psi. I think they are just about the perfect tyre.
Posted : 13/04/2010 3:33 pm
Over in Morzine a couple of years ago, I had a set of 2.3 Stick-E Nevs. On our way back from a ride, cruising down a tarmac road descent, the kind where you can get quite a bit of speed up without pedalling...my mates took off...with those tyres I was *slowing down* unless I kept pedalling. They also put me from the front to the back of my regular night rides at the time. I guess my choice was to MTFU or change tyres...I went for the latter 😉
Posted : 13/04/2010 3:40 pm
I always thought Stick-E front and back was a DH thing only!
Posted : 13/04/2010 3:46 pm
I've got 2.35 DTC Nevs on my Orange Five and currently using the 2.1 version on my Anthem X. FWIW, I run 'em tubeless with Stans gunk. I've also tried Advantages, Minions, er...and loads & loads of others (got a bit of a tyre habit y'see).
Keep coming back to the Nevs, 'cos I think they've got a good pretty good balance of lowish rolling resistance, grip and mud clearing. I'm a pretty aggressive 'XC/trail' rider and love ripping berms and carving corners - and haven't had any problems with cornering grip, although the 2.35's are definately more confidence inspiring for real mentalist cornering :-).
Posted : 13/04/2010 5:32 pm
Earl said it spot on.
Draggy but good all round.
Personally I would still buy season/weather specific tyre but if you're on a budget or ride few times etc then this could be your tyre unless it's very dry.
Posted : 13/04/2010 5:46 pm
2.1 DTC on the rear is a great option IMO, very grippy, not slow for what it is. But on the front, either a stick-e 2.1 or a DTC 2.35 is better, deals far better with rocks and roots and the like.
I really like the 2.1 stick-e/2.1 DTC combo... Fast enough for local XC, grippy enough for fort william. Kinda 😉 The 2.35 stick-e is a [i]lot[/i] slower, it's like a different tyre.
Posted : 13/04/2010 6:11 pm
Cool - mostly +ve then - thanks - I'll try them on the weekend 🙂
Posted : 13/04/2010 9:32 pm
If you're finding problems with running them in a pair, give me a shout, my rear one's getting a little worn so I could make a home for it and i've got stick-e blue grooves in 2.1 and 2.35 which would make a better front tyre so we could probably work something out
(I won't lie, I don't like the blue grooves but The Internetz does so I must be wrong 😉 )
Posted : 13/04/2010 10:53 pm
OK ill keep that in mind Windy 🙂
Posted : 14/04/2010 6:40 am
