Is this fecked?
[Closed] Is this fecked?
22 Users
There. Its the headtube of my old faithful hardtail, only ever used to ride on the road to work.
Opinions please.
Posted : 11/04/2010 8:32 pm
yes, all I can see is two red crosses!!
Posted : 11/04/2010 8:34 pm
What is it?
Posted : 11/04/2010 8:38 pm
Sorry image posting brain spaz. Sorted now.
Posted : 11/04/2010 8:39 pm
How old is it?
No I wouldn't advise you to use if cracked.
Dam gone right through as well.
Do you like to have a broken nose and no teeth with a trip to casulty?
Why take the risk? it's lasted a decade for you which is good.
Now buy a new frame.
Health=priceless.
Posted : 11/04/2010 8:40 pm
12 years old..... Only been used for the last 8. Like i said road only fully rigid, rode the frame twice offroad at the most.
I'd say keep an eye on it to see if it starts getting bigger?
Posted : 11/04/2010 8:41 pm
Look like the crack goes through doesn't it? Seems very dodgy to me... Not worth the risk!
Posted : 11/04/2010 8:42 pm
On the headtube? I wouldn't ride it, you might not have any warning when it goes. Your face will hit the ground pretty hard when it does.
Posted : 11/04/2010 8:43 pm
I dont think a scratch would go through to the inside though! Wish it was just a scratch! 😐
Yep, that's a scorpion grind face plant waiting to happen right there! 🙂
Posted : 11/04/2010 8:45 pm
Ok, since im the original owner of the frame and otherwise its unmarked, no stone chips, dents or dings. What do the collective think my chance of getting a warranty replacement?
Its a Marin Rocky Ridge from around '98. It was stored in the attic for 2 years before being used as my work bike in 2001.
I believe this has a lifetime warranty, but i could be wrong.
A bit gutted as it was getting stripped down for some TLC and a new drivetrain fitting, was going to use it a my 2nd bike, as no longer need a work bike as i've changed jobs and walk to work instead now.
Posted : 11/04/2010 8:49 pm
If it's got a lifetime warranty you can't go wrong can you? Can you take it back to the shop you bought it from....?
Posted : 11/04/2010 8:56 pm
dont ride that. you will end up with a hurty face. whats the warranty on a marin?
Posted : 11/04/2010 8:58 pm
The shop is about 20 miles away, no problems there. I accept its not for riding, but its never had any offroad abuse to speak of, so I don't think it should of cracked there. Will speak to the shop in the morning and take it from there.....
Posted : 11/04/2010 9:36 pm
yeah speak to the shop, if its under a lifetime warranty they'll have to replace it if they deem it dangerous and will most likely have to give you a newer frame!
Posted : 12/04/2010 6:22 am
Jubilee clip will sort that. No problem.
Posted : 12/04/2010 7:06 am
take it to the shop with reciept etc, and see what marin say. Cracks like that ain't massively uncommon and marin are usually good with warranty stuff.
Posted : 12/04/2010 7:09 am
brant - Member
Damn, somebody already suggested it, still I feel vindicated by somebody who should know having the same idea 🙂
Don't think I would risk it without a jubilee clip though...
Posted : 12/04/2010 8:34 am
Go in gently though. Lifetime warranty might only cover manufacturer defects which I think you'd be hard put to justifying after tweleve years. If I got tweleve years out of any frame, on or offroad I'd be chuffed to bits, retire it gracefully and move on.
Posted : 12/04/2010 8:39 am
IIRC Marins lifetime warrenty runs out after 10years... no not exactly a lifetime, but probably more than the expected lifetime of a frame.
Personnally I'd say you've got your money out of it, either hang it on the wall or weigh it in.
Posted : 12/04/2010 9:05 am
Yeah, im thinking the same thing tbh.
I've spoken to the shop, need to get some frame details and he'll see where I stand.
The annoying thing is a i've a brand new drivetrain to fit to it, gaaah!
Posted : 12/04/2010 12:11 pm
From the size of that crack I would say it will fail suddenly and catastrophically, rather than just continuing to propagate. Up to you but I'd cease riding it now mate.
Posted : 12/04/2010 12:16 pm
do the bmx madskillz trick (tm) of winding a nice big metal pipe clip round the outside.
problem solved?
Posted : 12/04/2010 12:25 pm
Given its a bare frame, not much chance of riding it!
Hmm what pipe clip to hold a headtube together....
Posted : 12/04/2010 5:33 pm
be right, just go easy and lean back a bit more (careful over the kerbs though)
Posted : 12/04/2010 5:36 pm
Pfft. That'll buff out.
Posted : 12/04/2010 5:44 pm
I always think the "I don't use it off road' thing is a bit of a red herring, sure hitting the ground/rock/tree is no fun if it does break big time BUT if it goes on the road what about all those cars/buses/taxis/tin boxes?
Just a thought 🙂
Posted : 12/04/2010 5:45 pm
YOU'RE DOOMED! If you even so much as look at that frame again, every single component will completely crumble to dust and you will die a horrible painful death by being killed by death in a horrible way. You will be mutilated beyond the point where a coroner can identify your remains as Human. Never touch any bike ever again, wrap yourself in bubble wrap and hide under your bed! 😯
Posted : 12/04/2010 5:48 pm
bigyinn - Member
[b]Hmm what pipe clip to hold a headtube together....[/b]
[url= http://www.zeroclips.com/heavyduty.htm ]I think a stainless one will match nicely?[/url]
Posted : 12/04/2010 5:49 pm
Wot no purple anodised ones? Pah!
Posted : 12/04/2010 6:08 pm
If it's an alu frame it could easily be put down to having reached its end of life - it's not at a weld, it's not in a high-stress (in that direction) location unless you've been doing lots of drops/jumps, so it's fair to assume that your frame has served you well, and finally requires retirement.
Posted : 12/04/2010 6:14 pm
Sadly CK i fear you are correct, will see what Marin come up with though, as its had an easy life really. 30 miles a week on road only, thats not a hard life is it?
Posted : 12/04/2010 8:01 pm
Easy fix.
A cable tie, bit of araldite and duct tape. No problem.
Posted : 12/04/2010 8:05 pm
You could hacksaw through that crack install a fork with headset etc and it still wouldn't fail. Might flex and move slightly but it wont fail catastrophically. You'd have to use a 10 tonne press to move the fork out of there. 10 yrs not a bad return on an ally frame. Jubilee clip will hold it no problem or get a split bush made like a OS bar clamp from local machine shop. There's life in the old girl yet!
Posted : 12/04/2010 8:14 pm
