How real is steel?
[Closed] How real is steel?
philjunior - Member
the CEN tests are just a fatigue test too, after all. If steel frames were failing it, what does that say for their durability?
If frames that weren't failing in real use failed the test, what does that say about the test design?
tall_martin - Member
The magazine tested this year's ago. They had a black and white charge hardtail in. Anyone who rose one had to ride the other and describe the differences. One was lighter by an amount you would notice in a magazine test but that wasn't commented on much. Other than that people didn't describe much difference.
As Jameso says, that tells you something about those 2 frames. Only mugs think that all frames of a similar material ride the same
You could run the same test with 2 different years of 456 and have people feel a difference (frinstance). Or the abovementioned gen 1 scandal vs inbred, where you'd get the opposite result from cliche. But equally you could repeat the Charge test with Cotic, and there's practically no chance people wouldn't feel a a difference between my old Soda and my BFe
(there's always the oblivious outliers who can't tell when all their pivots are seized solid or their shock has 20psi in it)
Posted : 13/01/2017 3:56 pm
 Del
like i said, i ripped the head tube off one of my pre-CEN test steel frames. I'm glad someone's keeping an eye on these squirrels. 😀
Posted : 13/01/2017 4:19 pm
kaya23 do you think Trek, Spesh etc. don't ride bikes? The difference is they can employ many people to test, provide feedback etc. and have done as much innovation in recent years as anyone, for example the Trek Superfly 29er almost instantly became the XC bike to be riding.
Del - Member
And people do the same to CEN-tested frames...
Posted : 13/01/2017 4:20 pm
 Del
sounds like the tests need stiffening up! 😆
Posted : 13/01/2017 4:50 pm
dragon - Member
Well yes I'm sure many of them and their employees do, but perhaps as a percentage of the entire workforce, it may be higher for smaller brands. I just imagine that smaller companies are perhaps not so absolute and 'tuned' in their marketing budget.
Rightly or wrongly, I imagine the marketing BS generators are stronger and larger at much richer companies.
Posted : 13/01/2017 4:58 pm
There are fatigue tests - I think for a German mag - that will back this up - and the CEN tests are just a fatigue test too, after all. If steel frames were failing it, what does that say for their durability?
Do not confuse strength with durability.
Don't confuse fatigue life with strength. The CEN test was a fatigue test. It wasn't measuring any other form of durability.
Of course if we're talking ability to resist dents, there are too many factors - a lightweight steel (or ti) frame will be tinfoil thin, but have smaller diameter tubes, whilst Al. will have larger diameter thicker walled tubes. Carbon won't really shatter if you so much as look at a rock, but can suffer in impacts (and can be designed to take a reasonably large impact).
As with anything else, it'll come down to how it's been designed as to whether it'll survive a blow.
Posted : 13/01/2017 5:04 pm
35 years ago I came off my Raleigh Budgie(hi ten steel) on a fast road descent and knocked myself clean out !
I'm now bombing Downhills on my genesis io(Reynolds 520) not knocked myself out yet 🙂
Guess cheap steel isn't real but good steel is more real ?
Posted : 13/01/2017 5:18 pm
Northwind - Member
Del - Member
2 good points...
I would guess fewer CEN tested frames fail, but some are still going to. Hopefully bikes are getting better, and stronger where they need to be, but some will always fail and anecdote isn't really proof. I've seen cracked frames in all sorts of locations, head tubes ripping off aren't good and even if it only happens to 1/1000 bikes, that's a lot of people having at best a nasty accident...
Posted : 13/01/2017 5:21 pm
There is a video on the Jones website, where Jeff demonstrates the vertical flex in a Ti Spaceframe. Ok, it is a Ti frame, so there is that, but you can have vertical compliance and lateral stiffness.
I'd be interested to see a video of the same demonstration with a steel Spaceframe.
Posted : 13/01/2017 5:38 pm
FWIW I have to agree with Kayak23, I had a PP Shan for a bit, and it was by a country mile the nicest riding steel HT I've ever been on, and like many here I've had a few. Really smooth, really forgiving,
TBH I thought the ovalised stays were marketing BS, I put it down to the length of the TT, a long unsupported tube. That, and it's predecessor was a SC Cham, so damn near anything would have felt softer!! 😆
I've got a Bfe. I had a Canyon Spectral. I prefer the Bfe as I just prefer hardtails and this is easily the best I have had and I have had a few. If you could stretch to a Soul I would imagine it'll be betterer but the Bfe is great too. Here it is..
[URL= http://i1066.photobucket.com/albums/u414/leythervegas/HINDLEY-PC/20170110_160820_zps8bfyfqym.jp g" target="_blank">http://i1066.photobucket.com/albums/u414/leythervegas/HINDLEY-PC/20170110_160820_zps8bfyfqym.jp g"/> [/IMG][/URL]
Posted : 13/01/2017 9:16 pm
I dunno if it is because steal is more "real" or because it is marketing hype that I have never managed to shake. I DO know that the only bike I loved instantly it was a Cotic Soul and it remains my favourite bike and the only one will I not ever sell. I have had it around 8 years now and keep coming back to it.
Posted : 13/01/2017 11:08 pm
Materials aside, one of the biggest contributing factors to how comfortable a bike feels (assuming hardtail) is down to wheelbase growth and one of the biggest factors in this is toptube and downtube flex. Much more than shaped stays (again assuming traditional diamond frame.
Posted : 13/01/2017 11:30 pm
Shandcycles, assuming the same tube shapes (if possible), are pre-CEN top and down tubes more flexy/comfortable/zingy/real than post CEN tubes?
Posted : 18/01/2017 2:44 pm
This now makes sense as to why mrs_OAB's Superfly has such a flattened top tube.
Noticeably, she thinks the superfly is less comfy than the old Cannondale F900sl, but that was made out of very, very thin alu (I can flex it like a drinks can on the downtube - careful with that bike rack now 😯 )
Posted : 18/01/2017 2:54 pm
 PJay
I know very little about the science of frame design but am aware of the argument that most 'comfort' in a steel frame comes from toptube flex. However, just to add my experience to the mix, I moved from an 853 Inbred (lovely and comfy) to an 853 Pipedream Sirius. The Sirius felt a perfect fit but very harsh at the back compared to the Inbred. Later I moved to a 853 Pipedream Scion (which I still ride and love) which felt instantly much more comfortable. The Sirius and the Scion have identical geometry and tubes, with 1 notable exception; the Sirius has 19mm seatstays whilst the Scion's are 16mm. I don't know why it makes a difference, but it does (as Pipedream claimed it would when I asked about it); it can't all be in my head.
Posted : 18/01/2017 4:25 pm
It's worth remembering that steel is greener than alu, to do with carbon footprint involved in making the frame.
Add that a nicely made frame can have the nice 'zing' and sense of feedback about what's happening under the wheels too, and that's a good mixture I think...
Posted : 18/01/2017 6:45 pm
It is? Sauce?
Posted : 19/01/2017 7:58 am
Sauce?
Will this do/work?
[url= http://theconversation.com/the-trouble-with-aluminium-7245 ]Linky[/url]
Aluminium needs 10times the processing energy of steel...
Posted : 19/01/2017 8:25 am
It's not just the frame. Wheels/tyres make a huge difference.
Posted : 19/01/2017 1:30 pm
I did not know that!
Posted : 19/01/2017 1:33 pm
While that is true, the steel market globally is massively oversupplied compared to that for aluminium (steel 15 million tonnes, aluminium 277,000 tonnes). So in reality there isn't a compelling environmental reason to buy one material over the other.
Posted : 19/01/2017 2:16 pm
Yes but most aluminium products are not made from virgin aluminium. It's usually made from aluminium that has been recycled multiple times, and it takes about 5% of the energy to recycle aluminium than to make it new. Same with Steel products, but not sure of the relative energy requirements and environmental impact of recycling aluminium vs. Steel.
Posted : 19/01/2017 3:42 pm
wobbliscott - Member
...not sure of the relative energy requirements and environmental impact of recycling aluminium vs. Steel.
i think... that's covered in the link.
or not...
Posted : 19/01/2017 3:52 pm
I think using the energy requirements to extract the raw materials is fine if you consider the other energy requirements, and the energy requirements of making the other (mostly aluminium) bits of the bike.
Might be worth worrying about for a tonne or so of metal, less so on a 1-3kg frame that you'll keep for 10 years or more.
Posted : 19/01/2017 4:15 pm
Ten times more energy to produce? Well crikey...
I just went and found a summary of that CSIRO report and you are correct.
Of course globally we also produce 24 times more steel than aluminium, and hence the process is probably better refined and marginally more efficient for steel...
They make the point that both steel and aluminium production could be made more energy efficient especially for smelting, where both expend the majority of their embodied energy...
Steel is the bigger source of CO2 emissions, but only due to the huge volume produced. Per ton aluminium is the worst polluter (CO2).
Of course that's only looking at ingot production. There's no through life analysis, Aluminium apparently uses ~1/4 the energy of steel for recycling, and there's not really any analysis of transport or eventual manufacturing energy use/derived emissions, nor is there much consideration that at 1/3rd the density of steel, a ton of aluminium goes further (volumetrically)...
I will accept it's a pretty energy intensive material to pull out of the ground and refine, but for it's full life cycle, there's a fair few ways it claws back some ground... I am still not convinced it's substantially "worse"...
Posted : 19/01/2017 8:09 pm
 core
Does anybody actually care about the C02 credentials of their bike frame?
I don't, I care what it rides like, then what it looks like. It's carbon footprint will be tiny in real terms.
I ran over and killed a rabbit on my bike once too.
Posted : 19/01/2017 8:20 pm
Well it was cited as another way in which steel is more betterer.
Do I care? I guess I do, but it's not top of the list, of course if prices for goods were properly linked to emissions and energy use, then I bet you would care more...
Posted : 19/01/2017 8:33 pm
Hydro-electric Scottish aluminium
http://www.telegraph.co.uk/business/2016/11/23/rio-tinto-sell-scottish-aluminium-smelter-liberty-330m/
Page 3 / 3
