Hope V4 caliper on ...
[Closed] Hope V4 caliper on an F mount (IS to PM 160 rear)
Thinking of fitting a V4 on a 160 rotor to the rear of an IS equipped frame. Think I'm right that it needs an F pattern mount.
Can anyone offer any advice? Will the bottom of the caliper clear the mount or will it clash? I know I could use an M4 but I'm looking to minimise spare pads and seals.
Can anyone help?
Posted : 04/12/2012 10:08 am
Anyone?
Posted : 04/12/2012 11:19 am
Oh no, it's 'im again! :mrgreen:
A quick Google shows the current [b]M4[/b] being able to use a 160MM rotor with mount F (the calliper just touches the mount):
[url= http://www.flickr.com/photos/31019817@N02/4800870628/sizes/l/in/photostream/ ]
[img] [/img][/url]
The leading piston on the [b]V4[/b] is 2mm larger in diameter than the [b]M4[/b]. Add say another 1~2mm to the calliper body, the [b]V4[/b] probably extended down by ~3mm compared with the [b]M4[/b]. You could probably get away with taking a Dremel to the mount and fettle away some of the material...
Posted : 04/12/2012 12:24 pm
Thanks, that's exactly what I was looking for. your google-fu must be stronger than mine as I couldn't find a pic showing that clearly.
Posted : 04/12/2012 2:10 pm
Ah, just twigged who you are on the other forum!
(waves)
Posted : 04/12/2012 3:02 pm
*waves* ๐Ÿ˜›
Did some crude image overlaying in Photoshop and it "confirmed" a Hope mount F would need to be Dremelled about 3mm to get a V4 to fit a 160mm rotor.
However(!!), the calliper doesn't exceed past the centre-line of the IS51mm bolts... so this North Shore Billet IS to PM160 adaptor [i]should[/i] work as is:
http://www.chainreactioncycles.com/Models.aspx?ModelID=50124
Proof of the pudding would be actually trying it... so you're still the guinea pig. :mrgreen:
Posted : 04/12/2012 5:03 pm
I've given up on the wife's bike and just ordered her some m4 instead. At least I know they'll fit. As for my bike, the advantages I though v4 had over the existing v2 seem to be diminishing all the time. Plus they don't have the funky green bits.
Think I'll leave it a while. Really appreciate your help though.
Posted : 06/12/2012 10:20 pm
Onzadog - What are your impressions of the V4s after riding them for a few months, if you don't mind me asking?
Edit - Just realised you didn't get them in the end, doh.
Posted : 19/07/2013 8:47 am
