Is it the same conversion kit to go from 20mm to 15mm as from QR to 15mm (on the pro 2 front hub)
thanks
kurt
Posted : 14/04/2010 2:37 pm
I've not got a 15mm kit but havew swapped from QR to 20 so I think you should be fine which ever way you're swapping.
It will just be the diameter of the hole for the axle that is different
Posted : 14/04/2010 3:15 pm
Aye. As far as I'm aware, none of the kits use any bits from the other so its just a case of fitting the new adaptors to the hub body (no matter what was fitted there previously).
Posted : 14/04/2010 3:20 pm
You just pull the end caps out and put the new ones in, doesn't matter whether you're going from 15mm to 20mm or normal QR.
Thanks for that.
Kurt
Posted : 14/04/2010 3:30 pm
