Brake lever is now very spongy, will a good bleed resume normal order or is it something more serious / expensive?
thanks
I am ok by the way
If it pushed the lever in you may have popped a seal or over extended a piston on the caliper. So either a bit of fluid might have escaped or some air got in.
A bleed might sort it, or you might need to replace a piston seal.
Maybe you need to try some wider bars.
Blown a seal?
Thanks all - a good bleed sorted it but alarmed to see the lovely pink Shimano fluid was a black sludge when push up from the Caliper end. No blubber involved.
handlebars reset and ready to ride again.
Thats why you need to replace fluids every year or two - wear particles and dust gets into it
