HiFi help please (S...
[Closed] HiFi help please (Sound reflection query)
At 67ohm/km that gives you ~1.5 ohm for 25m - that's a lot. With ceiling speakers it probably doesn't matter but you can simulate it by testing them in situ with a resistance of that size in series.
Posted : 16/02/2012 12:46 pm
I will give it a go when I get to wiring them, I might be able to put the comms cupboard somewhere closer to reduce the wire length.
I don't see getting the lengths down to sub 12M though.
What sort of resistance should I be looking at max?
Posted : 16/02/2012 12:58 pm
<5% of the speaker impedance is the rule of thumb, so 0.4 ohm or less for 8 ohm speakers.
Posted : 16/02/2012 1:12 pm
maybe better off with some sort of wireless/powerline streaming to an amp with a remote control that is somewhat nearer to the speakers.
Posted : 16/02/2012 2:23 pm
Netstreams do an ip amplifier module which might work for you. They are about £700 though. We had some here for a test install , they're probably getting dusty in a cupboard somewhere... I'd have a Google and see if something similar for sensible money is available.
Posted : 16/02/2012 2:30 pm
I am wondering about that.
My current plan is, sorta like this:
Squeezebox touch in Living room connected to local speakers. (zone1)
Kitchen - Squeezebox Radio and some ceiling speakers (zone2)
Bathroom - ceiling speakers wired back to comms cupboard (zone 3)
Bedroom 1 - ceiling speakers wired back to comms cupboard (zone4)
Bedroom 2 - ceiling speakers wired back to comms cupboard (zone5)
Whole house will be wired with cat6, so I was going to run some extra cables into the ceiling space, even though I mighten connect them for a while.
Not sure how I will drive the ceiling speakers yet, but I know I don't really want to put devices in the ceiling voids if at all possible.
Posted : 16/02/2012 2:40 pm
so why do you think cat 6 is a good speaker cable?
Posted : 16/02/2012 2:43 pm
Woah! I didn't expect a mass dabate (hur hur) over this!
I can hear the change in some high frequencies......
3F: Correct me if I'm wrong but I always understood that a speaker classified as 'monitor' was designed to have a very accurate soundstage and response curve in a very tight sweet-spot because they were essentially listened to by one or two people sat very closely together (i.e. at a mixing desk etc.) Whereas 'normal' speakers have a greater sweet-spot. If you listen to monitor speakers, surely this explains why certain frequencies drop rapidly as you move away?
Regarding suggestions to get in-wall speakers fitted: Unfortunately the building work has swallowed the available funds currently, and Mrs BOAS will not want to sit looking at holes in the walls for the next 12 months while I save up for equipment she doesn't see the need for!
Thanks for your inputs chaps!
Posted : 16/02/2012 3:23 pm
Because, I have to wire the house for data anywhere so to run another cable isn't a major hassle, especially if it would work for background music.
If its truely awful, I will use proper speaker cable ....
Posted : 16/02/2012 3:31 pm
I'd use proper speaker cable TBH.
I know there's a huge amount of snake-oil around speaker cabling (I'm sure the search facility would enlighten you on the amount some have spent on 'directional' cables 🙄 ) but then there is some science to back up SOME of the claims, and from my personal experience the resistivity and capacitance in some (cheaper?) cabling does make a difference.
Posted : 16/02/2012 3:38 pm
Most of the speaker cables that people have made with cat 5 and cat 6 involve 'weaving' them to keep inductance and capacitance at reasonable levels, but I think they can still be problematic with certain amps that don't like high capacitance.
And you are wanting very long runs of speaker cable, so I would definitely avoid.
Posted : 16/02/2012 3:54 pm
 jwt
I used some 2.5mm² speaker cable from CPC about £50 per 100m (from memory), I was under the impression CSA mattered on longer runs, although mine are no longer then about 20m via a speaker switch, and sound fine.
Posted : 16/02/2012 7:46 pm
On cableing I would go for some fairly basic proper speaker cable
couple of quid a meter stuff should be fine - thats what I used and I have loads of cabling
Posted : 16/02/2012 9:17 pm
 jwt
Just seen the speakers below and wondered if it might be a solution for some?
http://www.whathifi.com/news/systemline-builds-apples-airplay-into-active-ceiling-speakers-for-no-system-sound
Posted : 20/02/2012 1:17 pm
Interesting thread and a common dilemma.
If the room is going to be very "live" with acoustics compounded by a vaulted ceiling, I'd say you'll need to compromise on ultimate audio quality. Especially since you mention that you have a proper system in another room. Therefore, if background music is the realistic aim, I'd go for a higher speaker count run at lower levels. It helps to alleviate the problem of the room sound imposing too much. As somebody mentioned, it's more or less the same as sitting closer to the speakers.
Definitely ceiling or in-wall speakers for this project. As mentioned, either KEF or B&W are good choices.
If you want the choice of having them flat when not used and pointing at you when required, KEF do some motorised ceiling speakers. They're rather spendy though!
If budget allows, why not run the room design past an acoustic consultant before you build? At least with some basic acoustics predictions you could iron some of the nasties out at the design and build stage rather than try to fix them afterwards?
Posted : 20/02/2012 2:10 pm
...why not run the room design past an acoustic consultant before you build?
*sigh*
I have difficulty persuading Mrs BOAS that speakers are a requirement in the first place. If I were to employ someone to do an acoustic assessment I might as well remove my dangly bits and hang them in place of the speakers.
Good point, and one I have made provision for with speaker cabling in the walls and floors. I've made a guess as to where placement would be best - I just hope I've got it right as the plaster is on the walls now!
JWT: Nice idea, but, well, how do I put this, I'd repeat the dangly bits scenario before owning an iAnything.
Posted : 22/02/2012 12:01 pm
Page 2 / 2
