Just upgraded from old old Pace forks, to some Rock Shox SID Team 2008 (bought off here) so am new to set up intricacies.
Have set up as per manual and bought them as 100mm travel. They're moving plushly and all seems well, except according to the stanchion guides, they're resting at c. 90mm travel ie. I can't get the 100mm guide to be exposed but at rest, they sit 10mm above the 80mm guide mark. Measuring the total stanchion showing = 95-100mm. Why won't they 'rebound' to give full 100mm travel?
Any help (explained in simpleton terms pls) would be fab
Ta
This is a relatively common problem with air forks and RS in particular. I think it has something to do with the negative chamber (the chamber that helps push the fork back to full extension) becoming flooded with oil. The negative chamber works on the last part of extension/the first part of travel I think, hence why if it stops doing its job, it causes the last 10% of extension to fail - doe that make sense.
Best thing to do is call TF Tuned as they can handle warranty issues and it's a relativel easy fix if that is the problem.
Ah - maybe makes sense. When I let a little air out of the -ve chamber, a little oil splurts out too
When you put more air pressure in the neg chamber than the pos - the stanchion lowers are forced up a bit. Some folk like them like this (gives better small bump compliance or summit). If you want to check (and have a shock pump) let some air out of the neg chamber until the the pos is about 10 psi higher than the neg.
Oh - and getting a little spurt of oil is normal: even a good sign. There should be oil in there.
cool - will try. And am I right thinking you inflate +ve first, bounce a couple of times, and then -ve?
Are they dual air forks? (2 air valves, one top, one bottom)
If so, have a gander at this little guide of mine -->
https://docs.google.com/Doc?docid=0AVAoGIWBz4H1ZGc5bjJxNTJfMGh2MmtiZGdr&hl=en
many thanks PP - v helpful guide
Mr PeterPoddy
that's flipping genius that is...cheers 😀
Will sort my new to me 2008 Rebas according to this tomorrow and hopefully won't find them to be totally mullered as I though they were today!
