Help, old Clark’s m...
Help, old Clark’s mechanical disc - what model is it/pads
3 Users
Hi, just got a sh wiggins Chartres 26 for grandson, after a bit of cable lubing, gear and brake adjustment everything is working really well and ready to rock, but I can’t find out the brake model, (tried Clark’s website and google) it’s an early Clarks, mechanical disc with no bolt or pin to hold pads at top (they’re on a spring @nd seem to fit into the caliper a bit, the inner “piston” isn’t connected to cable but is adjusted by moving a “large pad sized round screw in/out pad pusher” by Allan key, this is then locked in place by a small grub screw.
It’s these
https://www.ebay.co.uk/itm/374589236541?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338364432&toolid=11000&_ul=GB&var=643573909627&customid=EAIaIQobChMI9JfByKmiiQMVr5dQBh1CETuJEAQYASABEgKIW_D_BwE&gad_source=1&gbraid=0AAAAAC-JtwKjl5fhOSMCn5fSV-oGkHB1E&gclid=EAIaIQobChMI9JfByKmiiQMVr5dQBh1CETuJEAQYASABEgKIW_D_BwE
Just want to know as I’m assuming I can change the pads by compressing the spring and popping them out and what pads to get
Ta
Posted : 22/10/2024 5:00 pm
Yes
Posted : 22/10/2024 5:11 pm
Do you know the brake model no, or what pads fit , thanks
Posted : 22/10/2024 5:28 pm
I might have some
Posted : 22/10/2024 5:39 pm
If you give me half an hour I may have a brand new Shimano cable disc calliper tucked away that you can have for postage cost. I’ll summon some energy and go down to the workshop!
Posted : 22/10/2024 5:40 pm
Clarks Cycle Systems: CMD-21 MTB/Hybrid Mechanical Disc Brakeset Front & Rear 160mm / 160mm- -160MM https://amzn.eu/d/42QTU96
Posted : 22/10/2024 5:43 pm
Cheers, the cmd name helped me find them, looked for pads for them, got the model now and searched for the brakes.
They’re cmd17, with slightly weird stepped pads, but easy to get, so all good, cheers and thank you for helping me.
Edit, flip, they might be cmd21 as well, ok it’s pads out and take it from there.but it seems to be 1 of 2 and the pads are very different
Posted : 22/10/2024 5:50 pm
@towzer sorry, the brakes must have been in the last box that I took to the charity shop - they renovate old donated bikes.
Posted : 22/10/2024 6:04 pm
No probs wheels, they work ok, and it looks like I should be able to get pads, thanks though ?
Posted : 22/10/2024 6:29 pm
