Help! Can't bl...
[Closed] Help! Can't bleed SLXs!
4 Users
 FOG
I have bled a good few brakes over the years but I can't bleed the front SLX brake I recently bought for my Bike. I shortened the hose and it's never been quite right since.I have tried all the usual tricks but the best I can get is a very feeble stopping power worse than the 1st pair of Deore discs I had 10 years ago. Any suggestions gratefully received.
Posted : 14/04/2010 8:19 am
whats causing the difficulty mate? i've got them and they've always been a piece of piss to bleed.
how are you going about bleeding them?
Posted : 14/04/2010 8:26 am
 FOG
Usual tube from nipple to Container of fluid, Squeeze lever , open nipple -close nipple , gently release lever. Hardly any bubbles coming through but no improvement in braking.
Posted : 14/04/2010 8:29 am
 sv
Syringe and some tubing try bleeding bottom up. If they aren't bleeding maybe something else wrong? Mine had a bent a bent and fluid coudlnt return quick enough and it felt like they needed bled.
Posted : 14/04/2010 8:30 am
Yep that's where you're going wrong then. You need to bleed UP only, push fluid up to the reservoir in the lever.
Posted : 14/04/2010 8:31 am
 FOG
I'll give it a go! Cheers.
Posted : 14/04/2010 8:33 am
and give everything a good tap to loosen any trapped air bubbles
Posted : 14/04/2010 8:36 am
