Grrrr... have I bou...
[Closed] Grrrr... have I bought the wrong tool?
9 Users
Bought one of these:
Pedros Pro Chain Tool 2.0
and one of these:
Gusset Bling Slink Half-Link BMX Chain (1/8")
I kind of assumed a 'pro' chain tool would do all types of chains, but I've just gone to use it and it appears not?
Have I bought the wrong tool for the job? 🙁
Posted : 21/05/2010 1:01 pm
you need a half link chain tool
You spent the best part of £30 on a chain tool?????????
Posted : 21/05/2010 1:03 pm
I had the same problem - the link pin is too long on the slink chain. I ended up pushing it most of the way through with some mole grips and a right pain it was too.
could shorten it ok with a Park tool chain tool, though.
Posted : 21/05/2010 1:05 pm
 nbt
thomthumb - Member
No you don't, but you do need a tool that will take both 3/32" and 1/8" chains. That tool will only doo 3.32" by the look of it.
why does it not work?
though Park do an 1/8th specific tool CT-7
Posted : 21/05/2010 1:06 pm
If that does not work, I presume the links are to small you could probably fashion a bodge piece of mild steel replacing the bit that holds the chain as they can be unbolted if you understand.
The chain doesn't 'slot' into the holder properly, I guess 'cos it's too thick? There's no way to adjust the tool is there, something I'm missing? It's a 1/8" chain btw (edited my original post 😳 )
Posted : 21/05/2010 1:10 pm
I bought one of these way back in the 80's - fits most chains. A snip @ $9
Posted : 21/05/2010 1:12 pm
isn't it just a matter of getting a different thrust pin for the tool ?
[edit] oh I see, wrong width not different pin...
Posted : 21/05/2010 1:20 pm
