Giant Trance back e...
[Closed] Giant Trance back end movement
6 Users
Hi all,
I have a 2007 Giant Trance which has been regularly used and has been self serviced, other than things like wheel truing etc. However Ive just noticed that if I put my hand on top of the rear wheel, and pull up on the saddle, there is a definite movement from the back end, like a bit of play which Im sure shouldnt be there. Is there anything self servicable or does it need attention from the LBS?
Posted : 23/03/2010 10:42 pm
shock bush
Posted : 23/03/2010 10:52 pm
as above. mine is doing the same after about 5 months... i should swap the bushes, but i'm lazy.
Posted : 23/03/2010 11:00 pm
If you can feel a clunk when lifting it and dropping it then it's the shock bushings, however a side motion shouldn't be due to them.
Disconnect the shock and give the rear end a good old wiggle in a solid workstand. If any of the bearings are rough or loose then replace all of them.
Posted : 23/03/2010 11:10 pm
Clunk when lifting saddle is shock bushings and cheap to replace. Sideways sounds like bearings and 2 years is about right to change them
Posted : 23/03/2010 11:22 pm
Mine was doing the same. LBS replaced top shock eyelet and bushes for £12 and it is as new again. Easy to remove shock yourself and check for rough bearings at the same time...
Posted : 24/03/2010 8:31 am
