Front QR with a lot...
[Closed] Front QR with a lot of torque.
8 Users
 juan
Right, front wheel on the SO's bike keep getting a bit sideway under braking.
Now I know it's nto due to the brakes, they are hope XC4 in 150 mm diameter, so plenty of modulation but not a lot of power.
The QR came with the bike. It's a sunn braded one with an external cam. I have just swaped it for an old mavic that I had lying around. It's a tad better but axe still goes a bit sideways.
So shall I order shimanos, or is it something else that will clamp the fork better?
Posted : 01/05/2010 5:44 pm
if she carries a 5mm allen key round with her, a bolt-up skewer would be good. I've got one lying around somewhere if you want.
bisous, J.
Posted : 01/05/2010 5:56 pm
 juan
julian yes good move how much do you want for it?
Bisous back 😉
Posted : 01/05/2010 5:58 pm
Change the qr for a shimano one now - unless you'd prefer her with no front teeth? Shimano qr's - beware of expensive imitations
juan, yhm.
Posted : 03/05/2010 7:30 am
^ what rich says shimano QRs are superb
but whatever you do, do it before you ride again. front axle coming out of the dropout is something you do not what to deal with (ask Russ Pinder 🙁 )
what fork is it? does it not have lawyer tabs on the drop outs? this would normally stop slippage
Another option (esp if you have a shimano hub) is rebuild the hub with a solid axle and nuts , old school but effective
Posted : 03/05/2010 7:37 am
Wasn't there a website where you could buy industrial versions of the dt rws for a fiver?
If I was looking for new, I'd try them.
Posted : 03/05/2010 7:55 am
 juan
Fork is a suntour. The axle doesn't come out due to the lawyer tabs (as you said). It's just that under breaking (very mild one I shall say) the wheel tilt a bit and that lead to disk rubbing and overheat build up in the brakes.
But yes I'll go and get some shimano at the lbs this week.
HALO Hex Key
Posted : 03/05/2010 7:59 am
Juan, are you sure it's the hub moving relative to the fork legs and not that the fork legs are just a bit noodly and are twisting as you brake?
If you check the inside of the drop-outs and look for any scoring where the hub sits, that should be able to tell you if the hub is actually moving.
Posted : 03/05/2010 8:00 am
 juan
well nick I am sure it's the hub moving
I usually put the wheel in close the QR, and then after the ride when I open the QR, the wheel falls back in the dropout
Posted : 03/05/2010 8:49 am
Have you seen that French film 'Baise-Moi'? I thought it was going to be a romantic comedy.
Oh dear... 😳
Posted : 03/05/2010 8:51 am
 juan
LOL
you're a bit out of topic my lil friend. No I haven't seen it but the title was a bit of a give away don't you think 😉
Posted : 03/05/2010 9:03 am
Well, I was of course going by the more traditional meaning of the word....
X
Posted : 03/05/2010 9:11 am
So are the insides/outsides of the dropouts scored from where the hub is moving?
And I know it's a silly question, but you are doing the QR up tight enough aren't you? And it's the same tightness when you remove it later? Or is the QR loosening as you are riding?
Posted : 03/05/2010 9:13 am
suntour fork with Hope XC4 brakes
you win the internet! 😉
Posted : 03/05/2010 9:16 am
 juan
Bikefascist care to explain?
Nick the QR is still as tight so I know it's not loosening as we ride. I'll check the dropout to see if there is damage.
Posted : 03/05/2010 9:25 am
