fox float problems ...
[Closed] fox float problems - possible causes?
2 Users
Hello all
I recently had my float 36 fit forks serviced. They did an oil change and replaced the seals. It was a reputable shop but a 7 hour drive away from here ( alpine bikes at inners ). They felt way too stiff straight after so I have been releasing the air pressure each ride since. I noticed that I have only been getting just over 60% travel so released all the air and still the same problem. The available travel feels as it should but I just cant compress them past the 60% mark !any ideas what could be the cause? too much oil ? Thank you
Posted : 02/09/2011 11:17 am
I think I'd drain them and refill with the correct quantity and then see where you are
Posted : 02/09/2011 11:26 am
Cheers ,
is it fairly straight forward to do myself or best sent to lbs ?
Posted : 02/09/2011 11:38 am
I guess that would have to be your shout really, I don't find it too difficult
http://service.foxracingshox.com/consumers/Content/Service/Forks/1.0_Fork_Disassembly.htm
Posted : 02/09/2011 11:46 am
