Fox F120RL - travel
[Closed] Fox F120RL - travel
5 Users
Do people actually get the 120mm of travel out of these?
I have been dropping the pressure gently and am now down to 75psi (10 less than the manual suggests) and still only 90mm. Static sag seems hard to check, but looks to be about the 20mm suggested.
Posted : 16/04/2010 2:40 pm
Nope
Posted : 16/04/2010 2:41 pm
are you sure thet are on 120mm as I have a pair and mine are set to 100mm due to the extra spacer I put in? Just a thought 🙂
Posted : 16/04/2010 2:46 pm
Thats the problem with air suspension as you compress it , the pressure gets greater because the chamber gets smaller so it ramps up towards the end.
Posted : 16/04/2010 4:01 pm
Came fitted to the bike, which was sold as having 120mm at the front - so I am guessing they were set to 120
Posted : 16/04/2010 4:16 pm
measure the length of stanchion
Posted : 16/04/2010 4:53 pm
10psi less than recommended for your weight is hardly anything. It will ramp up at the end of the travel as said and also if its a fairly new fork, it might need a bit of breaking in.
Posted : 16/04/2010 6:08 pm
130mm of stanchion showing so guess its set to 120. Might try a bit less pressure then.
Posted : 16/04/2010 6:49 pm
