I've got this: http://www.foxracingshox.com/bike/09/forks/32_TALAS/140_RLC fork with a postmount fitting and own a Magura Marta IS front caliper (180mm i think as it fitted to my Pike with a 180mm rotor without adapters).
How do i get it to fit?
is one of these: http://www.wiggle.co.uk/m/cycle/7/A2Z/ the only solution? if so which one?
* or anyone got a Magura Marta postmont front caliper in black for sale??? *
Ta
i use this one http://www.wiggle.co.uk/p/cycle/7/A2Z_Adapter_IS_to_PM_To_Keep_160mm/5360033036/ on my post mount fox talas with my 180mm hope caliper (its same as yours i think as i dont need adaptors to use on a 180 rotor) and it works fine mate
Double check its a 180mm brake/rotor not 183 or 185 then buy the correct size post mount to is adaptor.
http://www.chainreactioncycles.com/Categories.aspx?CategoryID=563
he wants an is to post tho burls with no increase in rotor size which is a bit more tricky as i found when looking
can i ditch the ball n socket gubbins that some PM use then too?
not sure what your on about mate
mebbe just an Avid thing - the roung concave / convex washers to "aid" alignment - pain in the arse - looks like they're not required on my set up
ah right no bolt mount to caliper and then to post mount easy 😉
cheers 😀
Sorry, my bad. I was reading brackets as fork to caliper rather than caliper to fork.
[b]Firetarter[/b]. that has just solved a problem for me (got IS caliper on a PM fork currently running 180 disc but on a carbon WW build) I didn't think you could get an adapter that maintained 160 with IS caliper on PM studs
TA!
no worries it took lots of searching to find when i first found mine 🙂 happy to be of service lol
snot working 😥
i've tried
http://www.winstanleysbikes.co.uk/produ ... pter_160mm
n
http://www.chainreactioncycles.com/Mode ... elID=21525
but it seems that because my caliper is 180 it keeps the caliper off of the disc
