Finally have to adm...
[Closed] Finally have to admit Bonty Mud X 29 sheet on front
15 Users
Washed out and faceplanted on Tuesday on muddy grassy terrain, front end was slipping on rocks'n'roots badly also.
I know I've been told that they're too thin but I'm old and stubborn.
Right then,
What's best for muddy,rooty,rocky slithery poop on front (sticking to my guns for now on back)
I need fairly good sidewalls also, so there we have it, oh and not heavy if poss.
I have searched previous but can't find anything that makes me feel the warm glow.
Posted : 20/12/2013 11:34 am
As a long term skeptic of using contis in anything other than dry conditions I've been quite impressed with how the rubber queen has been handling the slow descent into winter. It's not a proper mud tyre but I've found it pretty forgiving in the slop and good on the rest.
If they made barons in 29 I'd have one of those like a shot though. That was what really made me look at conti/black chilli again!
Posted : 20/12/2013 12:20 pm
Bounty mud x
(yes I read the post but they really are good)
Closely followed by Beavers
Posted : 20/12/2013 12:30 pm
Bounty mud x
Agreed, if you fell off using Mud Xs on muddy grass then I'd say something else is amiss.
Posted : 20/12/2013 12:31 pm
Had a similar lack of confidence with 29er storm controls. Seems to work great on the back wheel but didnt like the front on roots, rocks, techy stuff. Now have a 2.25 Beaver up front and initial impressions are its a massive improvement.
Posted : 20/12/2013 12:37 pm
njee20 - Member
Bounty mud x
no tyre is perfect & wet grass is Teflon coated, it's very rooty around here and nothing grips wet slimey roots, only technique & luck can save you on those. if I binned my tyres after every off I could start my own rubber plantation
Posted : 20/12/2013 12:41 pm
Ok maybe I overreacted to one of those nights......maybe persevere for a bit
Posted : 20/12/2013 3:26 pm
I run a Bonty 29-4 on the front of my ht with a mud X out back, seems to cope really well with everything I've tried to chuck myself down recently.
Posted : 20/12/2013 4:04 pm
I have a non black chilli Rubber Queen, it's the worst tyre in the wet ever and breaks away when leant over in the dry.
BTW
For sale, rubber queen 29er, three rides old
Posted : 20/12/2013 4:09 pm
I didn't think they were out yet?
Posted : 20/12/2013 5:11 pm
BTW
Haven't tried the non-BC versions in the mud, although a friend of mine seems pretty happy running the 26 versions. He runs them at a much higher pressure than I would and they don't seem to have killed him yet. Even the black chillis I would say aren't a mud tyre, but they handle the stuff fairly well.
Have you tried yours in heavy mud, or more wet roots and rocks? I would have thought the tread was the main thing in the thicker mud, the compound the big thing on roots etc, so I'd be interested to find the difference.
Posted : 20/12/2013 5:49 pm
 lump
Hutchinson Toro have been very good
Posted : 20/12/2013 6:03 pm
 ASC
HD trailstar up front Mud X out back. HD tubeless and about 18ish psi. Not falling off quite as much 😉
Wouldn't run with Mud X up front where it polished marbles or rooty.
Posted : 20/12/2013 6:16 pm
I like the beaver. Try the bonty with lower prsssure.
Posted : 20/12/2013 8:34 pm
Clink - Member
Indeedy, where did you get it from Warns?
I'm still looking for a wider than 2.0, 29er front tyre for wet conditions, was hoping to order a 2.25 Beaver a couple of days back but now the nextdaytyres site says the 7th Jan. Minions been suggested, but my Ardent isn't great, so I'm not convinced it'll be much better
Posted : 20/12/2013 10:35 pm
Tyre pressure
Posted : 20/12/2013 10:42 pm
Running mud-x 29's on my Trek XC superfly 100 sl
Found them to be better at 25psi front and 28 rear..I also run 25% sag in the winter instead of 20%
Posted : 20/12/2013 11:32 pm
Clink - I didn't think they were out yet?
I couldnt get any sensible info out of Maxxis UK about when they were going to be available so ordered from the US. Apart from a small customs fee and PO handling charge they werent that expensive and I like having the extra volume on the hardtail plus EXO carcass.
Also dont understand why Maxxis couldnt get this wet weather tyre out here in time for winter?
Posted : 21/12/2013 4:11 pm
I'm running a Mud-X 26 on the back at the moment and it's remarkably quick rolling but pretty drifty though predictable in the corners, good braking and driving traction and very sketchy on wet roots. I have a Baron (black-chili) up front which is amazing (though it leaked sealant for ages). Before that I had a Butcher which wasn't quite as good in the mud or on wet roots but better than most. Before that a Rubber Queen (black chili) which didn't have as much cornering grip as the Butcher or Baron in the loose/wet but wasn't bad and was very good in most other ways (including handling wet roots well). I think a Butcher Control 29 would be a good front winter tyre for most conditions if cornering speed matters more than straight lines.
Posted : 21/12/2013 5:17 pm
