Dropper levers and ...
[Closed] Dropper levers and brake mounts...
2 Users
 nbt
Couple of questions in here that may or may not need to be dealt with separately.
1) my bike currently has sram guide brakes, with an sram gx 11 speed shifter mounted on the right brake lever and a reverb dropper on the left brake lever
If I switch brakes and fir Hope Tech 3 levers, what extra parts will I need to allow the shifter and reverb button to be fitted?
2) Mrs NBT runs Hope Tech 3 levers, a shimano XT 11 speed shifter on the right and a reverb dropper button on the left. The shifter and dropper are mounted separately to the brakes. Due to injuries, she currently finds it difficult to press the reverb button with her thumb. Is there an aftermarket trigger (or perhaps even a different dropper if that's the only option) that uses a finger trigger? Less bothered in this case about mounting the shifter / reverb onto brakes but if it's possible, advice is welcomed
Posted : 13/05/2019 2:01 pm
 nbt
Bump for the evening crowd
Posted : 13/05/2019 6:57 pm
Haves look on the Hope website as there is a table with all the lever and shifter mounts on there; it’s what I referred to before buying on CRC
Posted : 13/05/2019 7:45 pm
