Bike Forum
8
Posts
7
Users
0
Reactions
101
Views
Is there a different method for cutting Carbon bars?? Or is it the same as aluminium i.e. pipe cutter or hack saw??
Posted : 23/05/2014 8:27 am
not a pipe cutter, it'll splinter the carbon.
wrap in tape, fine toothed blade.
try and do it outdoors.
I like to use a guide (old lock on grip or soemthing)to make sure I get a square cut - you can't just file it square afterwards
Posted : 23/05/2014 8:39 am
But wear a mask if you are filing, especially in an enclosed space.you can't just file it square afterwards
Posted : 23/05/2014 8:43 am
Measure once, cut twice yeah?
Posted : 23/05/2014 8:45 am
Ok thank you very much. Will try and find a fine toothed blade.
I use a bit of emery cloth instead of a file. Files can cause it to splinter at the ends.
Posted : 23/05/2014 9:07 am
Use a fine hack saw blade (32 tpi).
Posted : 23/05/2014 9:16 am
thanks guys
Posted : 23/05/2014 4:32 pm
And make sure there are no teeth missing on the blade
Posted : 23/05/2014 4:47 pm
