Cannock Chase Sunda...
[Closed] Cannock Chase Sunday - Tyre choice
10 Users
I've never been to Cannock Chase before, but am getting the chance on sunday, so I was wondering if the Panaracer Fire XCs are going to be up to the job, or whether I should whip them off and replace them with something else.
Anyone local got a preference for the best tyre?
Posted : 08/06/2011 10:42 am
Fire xc pro's are fine for the job, the best tyres though are those designed for dealing with general loose stuff etc....such as..
or any similar rivals.
Posted : 08/06/2011 10:46 am
Ace. Thanks.
I'll just stick some air in the normal tyres then.
If you're doing it properly you should take 2-3 different pairs and fit what works best on the day.
Best to pre-ride the trail first obviously, and account for drainage/weather changes before you do the "proper" ride.
Posted : 08/06/2011 10:48 am
I'd go for an mtb tyre every time over say a car or truck set......
Posted : 08/06/2011 10:50 am
Don't forget your permit.
2.7 supertacky Minions front and rear, dual ply, obviously.
If not, whatever you have on at the moment, it will be fine, there is nothing to overly challenge the tyres.
Posted : 08/06/2011 10:52 am
Racing ralphs, thin Nobby nics in the dry for me.
Although as above i'm going to give XR4 a go based on what other cannock regulars use.
If its wet something which will `stick' to the wet polished cobbles.
Tyres with some grip are fine. There is no slippy mud, wider treads can help on the pebbly bits.
All the Kewl riders use Bonty tyres from Swinnertons in Fenton.
Posted : 08/06/2011 10:54 am
other way, less pressure = less pebble related trauma
Posted : 08/06/2011 10:57 am
For a sunday ride you will need something you can bimble round on, no one does anything 'fast' on a sunday 😉
Posted : 08/06/2011 11:22 am
