can i run shimano s...
[Closed] can i run shimano splined rotors with avid brakes??
6 Users
im going back to shimano hubs but need a 20mm front hub and they only come with splined rotor fitting so i was wondering if i could get away with using a shimano splined rotor with an avid juicy 3 brake caliper with no problems??
cheers
steve
Posted : 30/03/2010 8:27 am
My mate bought a complete bike from Leisure Lakes with Juicy 3s and Deore CL hubs. Seems ok.
I have Avid rotors on XT brakes too.
Posted : 30/03/2010 8:39 am
any reason to not buy a centrelock to 6 bolt adaptor? assuming you already have a 6 bolt rotor you could use that is.
Posted : 30/03/2010 8:42 am
I've swapped rotors around no problem.
Posted : 30/03/2010 8:46 am
+1 no problem. If you have a particular liking for Avid rotors then I believe some of them are available in CL anyway.
Posted : 30/03/2010 8:50 am
I had a problem using BB7s and XTR rotors. I had to remove the wee "pad removal" tab from the inner brake pad.
Posted : 30/03/2010 8:26 pm
