Looking for the above.
12mm thru axle for front wheel.
Axle length is 172mm to start of thread and 194 to end of the axle.
1.5mm pitch thread.
Tried several places (Decathlon & SJS Cycles etc) to get replacement but with no joy.
Long shot but has anyone got one surplus to requirements or suggestions of other retailers who might stock?
Email SJS or better yet Robert axle project direct with your dimensions. They will tell you which axle to use. They sell spacers so one of the longer axles will almost certainly fit.
Tried SJS & had extensive emails with them to include all measurements. They were not able to supply a replacement.
Will try the RAP but was hoping I might find a more local (ie UK) solution.
Might be missing something here, I’ve got a set of dune forks on my fatty and the axle is 15mm in diameter?
Yup, is it a 15mm front or a 12mm rear you're after?
Plus it's Go Outdoors you want, not Decathlon.
I lost mine. Contacted Calibre bikes I think through Facebook, and they sent me a new one for nowt 😃
Yeah, I'm confused too. Front or back wheel?
That said, are the range of BX axles in stock at CRC at the moment, they cover a lot of bases?
